Old 10-02-2010, 02:31 PM   #1
Bypass Value for Hot Water Heater
We happen to live in Canada and will not be using our 330 TS Georgetown Motorhome for a few months. Therefore, I am attempting to winterize but can't find the bypass valve for the hot water heater. I think I have looked in every hidden compartment with no luck. There is one valve by the water pump that you turn when you pump in the antifreeze but for the life of me I can't find the other one. Does anyone have suggestions or know where this valve is located.
blackshadowk1937 is offline   Reply With Quote
Old 10-02-2010, 03:08 PM   #2
if your water heater is in the rear right side compartment, unscrew the plastic cap under cmpartment, reach up inside the hole and it should be attached to the water heater, its a pain in the butt to see, use a flash lite to see it .good luck, thats the way my 378 was
bad1032 is offline   Reply With Quote
Old 10-02-2010, 09:21 PM   #3
Same with my 373.
2010 373DS
Master Tow with 2008 Nissan Altima
bresdogsr is offline   Reply With Quote
Old 10-04-2010, 10:15 PM   #4
Thanks for the information. I gained access to the water heater and bypass valve from the an access compartment located under the motor home directly under the water heater. I never thought of looking there. Sometimes they don't make things to convenient. Once again thanks for the information. Have A Great Day.
Old 10-05-2010, 08:51 PM   #5
anytime, good luck
