We happen to live in Canada and will not be using our 330 TS Georgetown Motorhome for a few months. Therefore, I am attempting to winterize but can't find the bypass valve for the hot water heater. I think I have looked in every hidden compartment with no luck. There is one valve by the water pump that you turn when you pump in the antifreeze but for the life of me I can't find the other one. Does anyone have suggestions or know where this valve is located.
if your water heater is in the rear right side compartment, unscrew the plastic cap under cmpartment, reach up inside the hole and it should be attached to the water heater, its a pain in the butt to see, use a flash lite to see it .good luck, thats the way my 378 was
Same with my 373.
2010 373DS
Master Tow with 2008 Nissan Altima
Thanks for the information. I gained access to the water heater and bypass valve from the an access compartment located under the motor home directly under the water heater. I never thought of looking there. Sometimes they don't make things to convenient. Once again thanks for the information. Have A Great Day.
