Old 08-19-2015, 06:14 PM   #1
Cable splitter
We have a 2012 Georgetown 378 and am wondering if anyone knows where the cable splitter box is which runs the cable to the bedroom
bvbullock is offline   Reply With Quote
Old 08-21-2015, 11:53 AM   #2
The cable splitter is behind the front tv behind the false wall
tonytiza is offline   Reply With Quote
Old 08-30-2015, 08:31 PM   #3
I have a 2014 278ts with l/r TV, outside TV and b/r TV. The splitter for the l/r and outside TV is behind the fireplace which is under the TV. The splitter for the rear TV I found behind the wall in the right overhead compartment where the antenna switch is located. I had a snowy pictures the two front tvs but not the rear one. Started pulling the coax out of the wall and found the splitter. Every connections found anywhere in the coach was loose from the factory. Tightened them up and no more problems.
2014 Georgetown 378TS
2017 Explorer Sport toad
Benton, AR
Gbegoon is offline   Reply With Quote
Old 09-04-2015, 06:01 AM   #4
have found splitter but hard to access due to position behind T V from cubby hole in side of cabinet. know the wires are loose but can't get close enough to them. Help!!
Mike9224 is offline   Reply With Quote
Old 09-04-2015, 07:11 AM   #5
My problem was the first splitter after the antenna switch. Removed the wall plate and started pulling til it came out. Every connection everywhere was loose. Good luck!!
Benton, AR
Old 09-04-2015, 07:55 AM   #6
ourflat's Avatar
These connectors always find a way to come loose! I use a little blue Loctite to cure these blues!
Frank
KM4FVI
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 09-04-2015, 09:05 AM   #7
Frank
KM4FVI
Great idea to solve this loose connections.
