Old 07-20-2016, 08:51 AM   #11
Iggy's Avatar
Originally Posted by Paul S. View Post
Have you checked or changed the anode in your hot water heater? It may not be calcium but the deposits from the erosion of the anode.
X2
Yes it needs a new anode and when you replace it make sure you wash out the water heater tank with a hose a few times.
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Iggy is online now   Reply With Quote
Old 07-20-2016, 02:42 PM   #12
ccsvolsfan's Avatar
After washing out the lines with acetic acid, the remaining calcium will gradually disolve back into the water if you are now using a water softner. After a period of time the lines will self clean.
ccsvolsfan is offline   Reply With Quote
Old 07-20-2016, 10:31 PM   #13
Calcium is brittle.
If you can get to the lines to bend them the calcium will break loose. Check the screens in your faucets, that is the first place to clog. Especially if you break some calcium lose.
mnoland30 is offline   Reply With Quote
Old 08-14-2016, 03:57 PM   #14
How do you flush vinegar through your lines? pour it through a hose?
Mcaruthers is offline   Reply With Quote
Old 08-14-2016, 11:21 PM   #15
Your water pump has a small line on it to winterized your water system, run vinegar thru thou the whole system . make sure to remove all the tap and toilet filters and clean them.. Drain the system before you add the vinegar. GOOD LUCK
JW DUKE is offline   Reply With Quote
water
