07-19-2016, 12:56 PM
Calcium (hard water) deposit
I spend the summer at a camp ground where the wAter has lots of calcium therefore once or twice over the summer got to take the toilet water intake apart and remove deposit to have it run properly. Now I think I got hard deposit in my water line. Specifically the one going to the cold water line to the kitchen sink. What would you or have done to get rid of hard deposit throughout your water system.
Denis, Forest river Georgetown XL 377 2015, towing a 2014 Ford Explorer XL
07-19-2016, 01:09 PM
If the problem is really bad you can try diluted vinegar. You can add it via the winterizing port on the water pump. CAUTION: be sure to leave a faucet or two open as the reaction will produce CO2.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-19-2016, 02:02 PM
Need a good filter system that will remove most of the calcium from the water . We had the same problem with our stationary site, went to a the filters and have not have any problems since.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
07-19-2016, 03:36 PM
Senior Member - Retired
Kevin & Judy - what kind of filter are you using?
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
07-19-2016, 03:56 PM
Calcium is typically dissolved in the water. Mechanical filtration is not a good method. Water softener (ionic exchange) is your best bet. Something like this. http://www.pplmotorhomes.com/parts/c...FZE0aQodo-kA3A
John
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
07-19-2016, 09:10 PM
John just bought one of those, but I still have to get rid of what stuck in my water lines.?
07-19-2016, 10:13 PM
I think I would go the route that Flybob mentioned and let it sit at least 24 hours followed by a very good rinsing all done thru the winterizing port. This is just like taking the deposit build up out of the bottom of a house hold water heater vinegar can be used or they make a commercial calcium remover.
Retired Navy
2016 Flagstaff 26 FKWS
07-19-2016, 10:51 PM
Acetic Acid is what Vinegar is made from. You could use super concentrated version to remove it quicker. Maybe 8 to 1 for example.
B and B
07-20-2016, 03:52 AM
XL
Yes, and I would try the diluted vinegar that has been suggested.
John
Ohio
2015 Ford F-350
4WD SRW Diesel
07-20-2016, 06:21 AM
Have you checked or changed the anode in your hot water heater? It may not be calcium but the deposits from the erosion of the anode.
07-20-2016, 07:51 AM
X2
Yes it needs a new anode and when you replace it make sure you wash out the water heater tank with a hose a few times.
07-20-2016, 01:42 PM
After washing out the lines with acetic acid, the remaining calcium will gradually disolve back into the water if you are now using a water softner. After a period of time the lines will self clean.
07-20-2016, 09:31 PM
Calcium is brittle.
If you can get to the lines to bend them the calcium will break loose. Check the screens in your faucets, that is the first place to clog. Especially if you break some calcium lose.
08-14-2016, 02:57 PM
How do you flush vinegar through your lines? pour it through a hose?
08-14-2016, 10:21 PM
Your water pump has a small line on it to winterized your water system, run vinegar thru thou the whole system . make sure to remove all the tap and toilet filters and clean them.. Drain the system before you add the vinegar. GOOD LUCK
