Old 10-05-2016, 06:53 PM   #11
BillMFl's Avatar
Not running the gen set while refueling is for the same reason you should turn off the engine of your car or coach. The gen set exhaust is very close to the fuel fill. The new pump. handles seal off fumes better than the old days, but an accidental fuel spill can be ignited by engine or gen set heat/exhaust. Non residential frigs and water heater on propane are also a risk. The risk may be very small but if it happens the result is very bad. Once while fueling a guy filling his car was smoking! It was a calm day and the smell of fuel was strong. I politely said something and his response was to take a deep puff. I stopped pumping and walked away until he left.
BillMFl is offline   Reply With Quote
Old 10-05-2016, 08:11 PM   #12
World Wide Wanderer
wahoonc's Avatar
I am of two minds about this...
My generator is at the front of the coach, my fuel fill is about 18' away. Cars are coming and going from the pumps. My fridge is mounted pretty high, if it is on gas the flame is 5' in the air. I would say the odds are extremely low that I am going to spark a fire.
However I do plan my stops and turn the fridge and generator off prior to refueling.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 10-05-2016, 08:51 PM   #13
WI Sports Nut
mljuw89's Avatar
Thanks guys! Good advice!!
2011 Forest River Georgetown 378TS
Hales Corners, WI
mljuw89 is offline   Reply With Quote
generator
