Old 10-13-2017, 08:48 PM   #1
Can you run the furnace on 110?
Anyone know if you can run the furnace on 110? I have a 50 to 30 amp converter connected to another that brings it down to standard house plug. My niece and nephew want to sleep in the rig in the driveway but it will be cold. If I could run the furnace in my Georgetown 351DS that would make for a better night for them. Thoughts?
EricNJ is offline   Reply With Quote
Old 10-13-2017, 08:53 PM   #2
Fulltime family RVer
Yes but it also uses propane. Youíll need your converter on or good l/fully charged batteries.
Assuming you Moho is like a trailer.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 10-13-2017, 08:59 PM   #3
My gt300 runs the fan from 110 but the heat is propane!
Schvarak is offline   Reply With Quote
Old 10-13-2017, 09:07 PM   #4
Yup. Need propane. First cold night camping as newbies the Mother in Law came. Being the kind person I was, I let her have the bedroom while DW and I slept on the fold out. We got cold so we turned on the fireplace. Since I was too dumb to know how the furnace worked.
Next morning she mentioned it being cold and I thought "hmmm, maybe I should open the tank......"
JeffandLori is offline   Reply With Quote
Old 10-13-2017, 09:13 PM   #5
Flybob's Avatar
Just to clarify. The furnace runs on 12VDC and propane. When plugged in the converter provides 12VDC as does the battery to run the fan and control. Propane provides the heat. You can get a night or two out of battery ( not plugged in to shore power) depending on how much it runs.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-13-2017, 09:14 PM   #6
I have plenty of propane. I just donít want to run the generator and the only electric I have is the power from the garage. 15 amp circuit that can go through my normal shore power cord. So consensus is it should work right?
Old 10-13-2017, 09:14 PM   #7
bubbles's Avatar
Maybe a little clarity. The furnace is a 12volt furnace (fan/electrical etc.) and uses propane for heat. The furnace will run with or without 110 volts from shore power or generator. With = via the converter/battery. Without = battery only. Propane both ways.
Old 10-13-2017, 09:29 PM   #8
Sbryant's Avatar
Depending on how cold I believe you can run one ceramic heater on 110.
Sbryant is offline   Reply With Quote
Old 10-13-2017, 09:32 PM   #9
kenandterry's Avatar
EricNJ
If youíre connected to a 110 volt plug from the house on 15amp, your system will charge the batteries which is what powers the 12 volt fan of the furnace. Be aware, the propane consumption of the furnace is fairly high.
If you have an electric heater, you could run that and not much else, and not need the furnace IF it wonít get too cold.
If you are ever running your Georgetown off a 15 amp circuit, just think of it as one electrical outlet in your house. How many things, and what power draw could you run off that one outlet without blowing a fuse or tripping a breaker.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 10-13-2017, 09:33 PM   #10
Gumpster808's Avatar
Furnace should run ok connected to the outlet from your house. Normally it is the a/c that pulls too much current.
Depending on temperature I would go with the ceramic heater first to save the propane etc.
Just my thoughts though.
Lynn & Dennis
Nights Camped 2017 - 35
2014 3051S - First RV for us
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
furnace
