Old 03-27-2015, 01:41 AM   #1
Can you tow a jeep grand Cherokee
Hi guys I was curious if a Jeep Grand Cherokee SRT can be flat towed behind my Georgetown. Thanks in advance.
Htab is offline   Reply With Quote
Old 03-27-2015, 04:59 AM   #2
fonzie's Avatar
You don't say what year but here is 2014 dingy towing guide.....
Fonzie
Old 03-27-2015, 09:49 AM   #3
It should also say in your manual in the glove box
2011 Georgetown 337 2011 Chevy Impala
pakkdad is offline   Reply With Quote
Old 03-27-2015, 03:19 PM   #4
Krazymace's Avatar
Gotta look in your Owners Manual. Even if it's towable, there may be fuses that need to be pulled.
Krazymace is offline   Reply With Quote
Old 03-27-2015, 07:23 PM   #5
DarrenK's Avatar
May also exceed the towing capacity of the Georgetown...
DarrenK is offline   Reply With Quote
Old 03-28-2015, 12:36 AM   #6
You need 4WD in a Jeep to flat tow. That model is pushing the weight limit of a gas coach.
nicholsonv is offline   Reply With Quote
Old 03-28-2015, 02:27 PM   #7
oldprof1's Avatar
Towed my 2008 Grand Cherokee for 4 years. If yours has a quadra II transmission there is a small hole on the console. I forget what it says beside the hole -I sold it last year - where I inserted a nail to depress the switch. With the ignition "on", engine NOT running, foot on the brake, depress the switch with the nail and hold until the dash computer printout say's "neutral". Boy how easy it is to forget!! I did it all the time. Leave the transmission in PARK, lock the doors and pull away. The steering is unlocked, the transfer case is disconnected and there is nothing else you have to do. The procedure is in the manual.
Snow bird in naples
oldprof1 is offline   Reply With Quote
Old 03-30-2015, 09:32 AM   #8
What's the Max weight the Georgetown can tow? The curb weight of the grand Cherokee is 4500-5100 pounds. Would that work?
Old 03-30-2015, 05:13 PM   #9
DarrenK's Avatar
My '14 328TS has a 5,000 pound hitch. I assume that's pretty standard among the Georgetowns.
Old 04-06-2015, 10:03 AM   #10
If you have any warranty on your coach do not exceed your tow limits as it will void your drive train components warranty.
RLWilson is offline   Reply With Quote
cherokee
