Old 06-07-2018, 08:25 PM   #1
Canadian Satellite setup
Hey Everyone I’m currently getting a Wingaurd TRAV’LER dish installed in my 36B5. The question that I have is how can I set it up that I can have a separate reciver for the bed room and another receiver for in my living Room and also use in the outbdoor TV. And I have bunks with TVs so would they be ran off the bed room reciver. What works best and what have others done! Thanks for the help! Will be running the Shaw service.
Bigwheels90 is offline   Reply With Quote
Old 06-07-2018, 08:44 PM   #2
B and B's Avatar
Hello,
You require a separate coax to reach receiver to make it work, if you have a PVR you need two coax's at each receiver or run single coax mode and use one. No splitters, no switches. I run Shaw myself. Much different than Dish, Direct or Bhell.
B and B
Old 06-07-2018, 08:44 PM   #3
Senior Member - Retired
CA Fisherman's Avatar
Using DirecTV
I installed the DirecTV version so I have DIRECTV HD and SD. It uses SWM (Single Wire Mutiswitch) Technology that requires just one cable run to each TV. This dish uses a 3 LNB antenna which provides complete coverage of all DIRECTV standard and HD programming. Receives both KU-band (101°) and KA-band (99° & 103°) satellite signals simultaneously.
I paired it up with a Genie system supporting my three TV's. I have DirecTV in our home so DirecTV gave me the Genie hardware for the RV at no charge as long as they did not need to install it. Person at each TV can watch and/or record any channel they want up to a maximum of five channels at the same time.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 06-07-2018, 08:45 PM   #4
I have Directv. HD receiver in living room, splitter film there goes out to outside TV and a wireless HDMI transmitter goes to the bedroom TV.
Don't know what Shaw has but now Directv has wireless client based systems that attach to each TV each with separate remotes.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 06-07-2018, 08:47 PM   #5
B and B's Avatar
Keywords...
Canadian
Shawdirect
B and B
Old 06-08-2018, 02:26 AM   #6
Just a member
kandl's Avatar
Good grief... that's more TVs than I think I've owned in the past 30 or 40 yrs!
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
lite, satellite
