Old 08-20-2016, 11:00 AM   #1
Cannot Find A Part...
Any one know of a supplier? As always the KISS rule should be the first step anyone takes....house battery charging problems...so I tore the battery box apart...tested the solenoid...etc. Turns out, it appears, the coach disconnect switch is the culprit! If I wiggle and probe the connections on the back the switch engages and the electricity flows. Switch has 8 connections on the back.....only marking on switch is Mexico 1041 8961K2811 or 8961K2611. The last 8 or 6 is difficult to make out. Anyway....have searched various supplier sites and cannot find a replacement switch. Has anyone had this particular switch go bad and needed to replace it? Thank you for information that may be out there. thomanddebie
thomanddebbie is offline   Reply With Quote
Old 08-20-2016, 11:12 AM   #2
Check boat suppliers. Should be able to find a decent quality replacement part
donniedu is offline   Reply With Quote
Old 08-20-2016, 11:13 AM   #3
You can replace the defective switch with any brand. They're readily available at Amazon, eBay, and many auto parts stores; a web search for "rv disconnect switch" should provide lots of options.
Hope this helps.
ellen and ken, 3 dogs and Adventure Cat
2012 Mini Lite 2109S
2005 Sierra 2500HD Duramax/Allison
ekrus is offline   Reply With Quote
Old 08-20-2016, 01:16 PM   #4
jergeod's Avatar
Any napa store could help you and most stock that type switch.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 08-20-2016, 01:35 PM   #5
Iwannacamp's Avatar
Maybe. 21 years at NAPA here. I would seek an electrical distributor. They are used to these. Then of course there is the Internet.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Iwannacamp is online now   Reply With Quote
Old 08-20-2016, 01:35 PM   #6
Weekender
Ford1's Avatar
I think that this is what you are looking for, correct?
If so, here is the info;
Heavy Duty Momentary ON/OFF/Momentary ON Switch-1/card
from RV Parts Country
Heavy duty switch for Slide-Outs, generators, and battery disconnects. 1.22" x .98" Cut-out: 1.071" x .86" Six prongs.
See more details at RV Parts Country
$7.28
+$9.49 shipping. No tax
RV Parts Country
Let us know.
Mike B.
Ford1 is offline   Reply With Quote
Old 08-20-2016, 01:49 PM   #7
Mike B. Thanks....Yep looks like switch needed only mine has 8 stake on terminals on the back. Will research your web links to see if I can find one.
Thanks thomanddebie
Old 08-21-2016, 06:31 AM   #8
Tim & Lisa Trempert
Thanks thomanddebie
I believe yours has an indicator light. Hence the extra terminals.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-21-2016, 10:51 AM   #9
Trempert, Thank you for that info. This could be reason I can only find 6 terminal switches on line. Don't need the indicator light as it was ON in either position. Never did make any sence. Again, Thank you.
Old 08-28-2016, 07:58 PM   #10
What does this switch control???
"8" could mean 8 lugs........
A sketch of wires and color code to each terminal might help.
Any terminals jumpered?
Jim in Halifax is offline   Reply With Quote
