09-02-2011, 07:21 AM
90 degrees on both. They will face each other. It's a pain to do for so little of a change.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
09-04-2011, 08:27 AM
Drivers seat
We have a 2008 378ts had the same problem but from someone else on the forums we did it. You fold your back part of your seat forward and lower you seat all the way down, stearing wheel up, and as your turning it you have to put presure on the back of the seat. The lef arm has to be down. I hope i explained it okay. Good luck
01-18-2012, 08:11 PM
We have a 2012 378TS & just did the shakedown. Had the same issue but figured it out. For the drivers seat, hold the handle for the back tilt & bring the back down towards the seat more than 90 degrees & then it will clear the wheel with the wheel tilted up all the way. Once I did this the seat turned all the way around & I sat in it all weekend.
01-18-2012, 09:31 PM
I modified the seat slides and now mine will spin all the way around
2010 Georgetown 330
Ontario, Canada
01-19-2012, 11:44 AM
Anacortesians
Just 90 degrees inwards on both seats on ours. I have to monkey about with the driver's seat and steering wheel to get it round but it's not too difficult.
Frank and Eileen
1 Rescued Male Labrador - Bailey, 9 in July
02 Georgetown 325, F53 V10
01-20-2012, 06:34 AM
mine turn around easily however the first few times where exasperating ,it is just a matter of finding the right position to make your move cant explain it just do it
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2011wrangler mangotango toad
take us
01-24-2012, 07:31 PM
Co-pilot is a move it forward towards the dash, release the seat back so it folds forward and then turn it around. Pilot will go 90 degrees but I have never gotten it past the steering wheel. 2008 315 SE.
01-30-2012, 03:16 PM
Harleydriven64
Originally Posted by johnnypal
Thanks Ohio Bill! Im going to try it when I get my 11 378 ready for my next trip.
man is that pretty .... i have 2012 378, an turn them both around all the time to use when parked, start by tilting wheel all way forward, slide drivers seat back tilt back forward, work it up an down an around like that an it happens... pass. seat slide all way for ward an turn it, just need some patients an a beer helps but it does happen
04-14-2012, 10:31 PM
Harley you're the MAN!
Simple and straight forward.
Keep em coming.
2012 Georgetown XL 37' - Model 378TS Dinghy - 2012 Fiat Pop 2,323lbs
04-16-2012, 06:40 AM
Update: After speaking with FR rep (Rich Rowland)at the Timonium RV Show in February I tried once again to turn the seats around. Driver's seat can face the rear now. It's a multi-step process but is doable. The passenger seat was only able to face the rear at a 45 degree angle due to the barrel chair being so close. We replaced the barrel chair with a Euro-lounger and Ottoman. Now both seats can face the opposite direction.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 323 |
| 32 members and 291 guests |
| 12vdzl, 1l243, bclemens, Borwick, brookside, ChiefGeek, comox, davepcpowernet, Fester Carbunkel, flynmoose, Greene, honda1, House97, jcoff2003, Joseph5410, kixonrt66, klkdp, lami, Mountainmanbob, MrMeyer, Namchief, newtsx3, nrcamp, photog, rexerito, Rsgtivr6, Skippkon, sprayking, SpringerPop, Terier, toclark491, wagon52 |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
