Old 04-16-2012, 07:10 AM   #21
Iggy's Avatar
Originally Posted by cfsoistman View Post
Update: After speaking with FR rep (Rich Rowland)at the Timonium RV Show in February I tried once again to turn the seats around. Driver's seat can face the rear now. It's a multi-step process but is doable. The passenger seat was only able to face the rear at a 45 degree angle due to the barrel chair being so close. We replaced the barrel chair with a Euro-lounger and Ottoman. Now both seats can face the opposite direction.
OK I understand the steps to move chairs forward and back but is thier something under the chair that I must pull to unlock it to rotate? or does it magically release in a particular point?
Old 04-16-2012, 08:58 AM   #22
Send a message via Skype™ to Falcon35
I have turned my seats around.
I find that the drivers seat back is to erect to be comfortable.
The passenger seat is OK but you can't see the TV from there.
Iggy: Check down under the seat you will find the leaver.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 04-16-2012, 05:37 PM   #23
On our last trip I finally rotated both front seats in our 2011 378. At first I thought the drivers seat would not rotate completely. Then I realized I needed to run the power seat forward (now toward the rear of the coach). There was a lot of travel left and I could then move the seat back to a comfortible position. The tv was viewable and the room was very livable with the extra seating. We moved the recliner back toward the kitchen.
We probably won't turn the seats for an overnite, but it is worthwhile for longer stays.
ohiobill is offline   Reply With Quote
Old 04-17-2012, 06:27 AM   #24
CLASS "A" Senior Member
cfsoistman's Avatar
Each seat has a lever on the side that releases the seat to rotate it. Passenger seat has a lever in the middle of the front to move that seat back and forth. In the case of the driver's seat I had to lower it down as far as it will go and actually turn it towards the outside and loop the seat belt over it. I had to move the back of the seat forward and play with the front to rear adjustment as I turned. Personally for a weekend trip it too much of a pain but if we're going for a week then I'd spin them if our daughters are going with us, but most of the time it's just my wife and myself so we really don't need to turn them.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-17-2012, 09:34 AM   #25
Has anybody tried this? Have the DW hold the chair solid then you turn the coach under the chair........Just kidding.....
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
