Old 04-18-2014, 01:34 PM   #1
captains chairs
We have a 2014 georgetown 335. The arm rests on the passenger's captain chair are way too high. We've had them adjusted once but are still too high. Does anyone know how to do this? If not, do you know the manufacturer so we can maybe ask them? Thanks.
billmurray is offline   Reply With Quote
Old 04-18-2014, 02:51 PM   #2
abjb's Avatar
Interesting, DW says hers are too high I wonder if they were adjustable in 2012?
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 04-18-2014, 04:01 PM   #3
Ours are not adjustable either. From the looks of it, they are not adjustable. If they are, I'd like to know.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 04-18-2014, 04:15 PM   #4
Iggy's Avatar
You know you can remove them.
Push in really hard when they are in the up position and pull out.
Old 04-18-2014, 08:33 PM   #5
intercept's Avatar
Same problem here.
2012 Georgetown 378XL
Toad 07 Lexus RX350
intercept is offline   Reply With Quote
Old 04-19-2014, 07:55 AM   #6
Here is the position on ours which is a little bit too high:
To remove it bring it as far back as it will go, press hard on the pivot point, and it will rotate back a bit more and come off:
This piece is definitely not adjustable:
If there is an adjustment it must be inside this metal cutout where the metal rod on the arm rest will sit.
Old 04-19-2014, 09:29 AM   #7
RudysWorld's Avatar
I have a 2011 and thought the same thing, but now after adjusting the steering wheel and getting used to it the height is fine. Much higher than car and might just take time getting used to it. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 04-19-2014, 01:37 PM   #8
JimF's Avatar
Same as above, mine seemed to high until I settled in to the drivers seat, got everything adjusted for a long ride and they seem perfect. I also griped about them being to high but realized they are not.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is offline   Reply With Quote
