Old 05-16-2014, 07:38 AM   #1
Cargo Door Keys
Anyone know who carries these blanks and can make copies? The one that is used on the outside cargo doors. I've managed to get some of all but that one made so far.
Thanks,
fullenw is offline   Reply With Quote
Old 05-16-2014, 08:00 AM   #2
We had our dealer order us some from FR after one broke off in the lock. Not sure if they will be sending a key blank, or what. It's been on order for four weeks.
bkearney is offline   Reply With Quote
Old 05-16-2014, 08:02 AM   #3
Old Enough to Know Better
gasman6674's Avatar
Try this site I was able to order based on key number.
RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys
Good Luck
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 05-16-2014, 08:45 AM   #4
Thanks ill check these out and post back when I can
Sent from my SAMSUNG-SGH-I537 using Forest River Forums mobile app
Old 05-16-2014, 10:50 AM   #5
Iggy's Avatar
Thanks,
Is it the single sided notched key or the double sided notched key?
Either way if you find a real locksmith locally they should be able to find a blank and cut them.
You being in Indiana should make that easier as you are in the state that makes most rigs.
Old 05-16-2014, 10:55 AM   #6
If it's a double sided we went to a locksmith and they had to order the blanks in. It's a pain but at least you know you don't have the same key as everyone else.
sroarke
sroarke is offline   Reply With Quote
Old 05-16-2014, 11:24 AM   #7
mark0224's Avatar
Change those locks out and have them keyed the same as your door locks. 1st reason all the cargo locks for every camper are the same, my key will open your locks! 2nd less keys to carry. I used RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys and got new door locks and compartment locks from them they were quick and all the compartments and the entry doors use the same key. The old compartment locks, I did try our old campers keys on and those keys opened them. If our not changing them don't put anything of value in those compartments. Global Link Locks and Keys | RV Door Locks & Keys | RV Locks & Keys
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-16-2014, 11:28 AM   #8
ok, i ordered some key blanks but i may look into replacing the whole thing if i desire at some point.
Thanks for all the advice!
door
