Originally Posted by KEliasz
Went on very first outing with Georgetown 351. Stopped at cat scales on way to lake George. Scales said steering weights just over 7000lbs and rear at over 12000lbs. Goodyear tire load chart only goes up to 4600 for weights and recommends 110psi. Am I over weight? GVWR on sticker says 20500 lbs. I had the tires filled to 95. Dealer had the rears at 75lbs.
Front axle weight is 7,000lbs so that means 3,500 lbs per front tires
Your rear axles is 12,000 lbs so that means each tire is 3,000lbs
Your Gross weight is 19,000 lbs
Your Georgetown GVWR is 20,500 lbs
No you are not over weight just use the figures I said per tire and do not use the whole axle weight
