I assume your talking about the sponge backed vinyl ceiling, not the ceiling panel itself. The vinyl is held up by contact cement, I had a similar problem and fixed it by pulling the vinyl loose at the seam spraying headliner spray contact cement between the vinyl and wood ceiling panel, pressed into place, re-tucked the vinyl under the plastic seam divider, all has been good for almost 4 years. Good luck on it, was a bit of a headache.
JimF
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
