Old 05-29-2014, 06:56 PM   #1
GABoy's Avatar
Ceiling Fan
I've been looking into installing a 12volt ceiling fan with wireless remote in bedroom of our 351. Done the measuring and believe I can install a 36" next to rear ac cover between light and unit.
Anyone done this in your GT? Pros and cons on install and operation of fan?
I'm looking to have air circulation when sleeping as I do at the house to be more comfortable.
Any thoughts and ideas are welcome.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 05-30-2014, 07:19 AM   #2
I've been thinking the same thing. Interested in seeing if others have done this.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 05-30-2014, 07:29 AM   #3
My big head will find that fan every time. We leave the rear end AC fan on "Lo" at night. It provides white noise for the kids and helps circulate air.
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-30-2014, 07:54 AM   #4
The question I've got is how do you mount it? Is the structure in the ceiling strong enough to support it? Can you run the wires from a light through the ceiling to the fan to power it?
Lostdog
Old 05-30-2014, 07:58 AM   #5
GABoy's Avatar
I've done that too. Running on low is better to me than letting it cycle on off. The cycle on with compressor is little noisy from no noise when off. What I like best right now is to set front unit in fan on mode so noise is up front. I was thinking with a fan this would be good set up. Not sure though.
Chevy Colorado Crew
Old 05-30-2014, 08:05 AM   #6
GABoy's Avatar
The one I'm looking at has a motor base that screws directly to ceiling with rubber washers between. Cover goes over that. I was thinking of pulling power from light directly beside. If pull light fixture down and make 3/4" whole at fan base location should be able to snake wire to connect behind light fixture. Ceiling seems to be fairly beefy next to ac. Probably some frame braces there.
Chevy Colorado Crew
Old 05-30-2014, 09:10 AM   #7
What about one of those oscillating fans. You can put a small one in the side stands. Or better yet, one of those bladeless fans.
Not sure about mounting a ceiling fan just on the ceiling material. I'd have to look as it may be strong enough, but if not it could sag. Worse case scenario you could somehow install a metal bracket from the inside if you can get to it from the AC area.
Old 05-30-2014, 10:38 AM   #8
GABoy's Avatar
I agree. I would look for a frame stud or cut a slot to add a 1x4 above the ceiling for screws to grab. May be accessible in ac housing side with trim cover removed. Bladeless fan may be option. DW does not like fans sitting around that you have to lay down or take up space.
Chevy Colorado Crew
Old 05-30-2014, 01:05 PM   #9
Freds342's Avatar
On RV.net, there's a story about a guy who measured veeeery carefully, installed a ceiling fan, and then closed his slide.
Guess what happened?
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 05-30-2014, 01:09 PM   #10
Oh, no way! Maybe his fan had foldable blades
Old 05-30-2014, 01:16 PM   #11
Freds342's Avatar
He only broke off one blade.
Old 05-30-2014, 01:59 PM   #12
GABoy's Avatar
I had that same concern. I measured with slide in. Also was planning for blades to be higher than top of trim from slide. It is close though. Blade arm can be bent up slightly for more clearance. I guess no one has attempted with a GT.
Chevy Colorado Crew
Old 05-30-2014, 02:23 PM   #13
BamaBob's Avatar
Plus, not so sure I want whirling blades-O-death not 4 or so ft from my groggy head. I just know, SOME night I would smite myself on a midnight potty run!
Now, we have one in the living room (10-ish' cieling) it's nice there!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
fan
