Old 12-13-2010, 11:44 AM   #1
jsutherl's Avatar
Ceiling Molding
Between each of the ceiling panels of my georgetown there is some plastic molding. It's the kind that has a barbed nub along the back so that when you push it into the slot between the ceiling panels it stays.
I'd like to replace it as it's either yellowed or it was just made an ugly off-white. I'd rather have a nice white color.
Anyone know where to get this stuff? "Plastic Molding" is one of those things you can't search for on Google unless you want to know how to mold plastic.
2008 Georgetown SE 350DS BunkHouse
jsutherl is offline   Reply With Quote
Old 12-13-2010, 02:12 PM   #2
If it is possibly the same thing as automotive trim called windlace, you can possibly getit at a shop that does auto upholstery work, or even home upholstery shops. Other than that, your best bet is going to be calling the Forest River parts dept. to explain your need, and they could order it for you. Randy
08flagvlite is offline   Reply With Quote
Old 12-13-2010, 09:03 PM   #3
tazzerbp's Avatar
Try any any RV parts or service shop. If they don't have it in stock I'm sure they can get it for you.
tazzerbp is offline   Reply With Quote
Old 12-14-2010, 12:19 AM   #4
jsutherl's Avatar
Found it. It's called T-molding. My georgetown has 1" wide T-molding.
T-Molding.com : Plastic molding for arcade games and other products.
Thanks everyone!
Old 12-18-2010, 05:40 PM   #5
Whoa! there jsuther...I had a leak in my roof and had it all fixed up at the factory. But before it was fixed I had that molding up and down a couple of times. It's stapled to the ceiling with about a thousand staples and if it doesn't go up right it looks like crap. Plus tucking the ends in is not that easy either. I'm not saying not to do it, but just to change the color of it
hmmmm, I think I would find something else to do that needs to be done.
just my 2 cents......
Joe
JDickson is offline   Reply With Quote
georgetown
