Old 06-18-2014, 09:54 PM   #1
CGFI Issues on 2015 350XL
All my gfi plugs are not working. Went as far to replace the receptacle. I checked all the fuses and still not working. And thoughts?
Thanks,
Joe
Thanks,
Joe
2015 Georgetown 350XL
Ontario, Canada
tetonpizza is offline   Reply With Quote
Old 06-19-2014, 05:37 AM   #2
if one goes out, they all go out...like christmas lights...
check the one in the bathroom, and reset it at the plug. then check the others, one in the kitchen and the one outside in the basement storage....
they all reset at the plug....
2014 Georgetown XL 350TS
2014 Jeep Wrangler Rubicon Unlimited
Front & Rear Roadmaster Sway Bars
Koni Shocks
Front and Rear Sumo Springs Jounce Replacement
willingtonpaul is offline   Reply With Quote
Old 06-19-2014, 06:28 AM   #3
Grape Escape
Check the breaker
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 06-19-2014, 08:18 AM   #4
If you changed the GFCI and checked the circuit breaker (not fuse) then you may have a fault at the power pole. This has happened to me. Days of frustration changing out the GFCI with no cure of the problem. Changed to another site, another power pole, and problem went away. Go figure!
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
