Old 04-21-2012, 09:40 PM   #1
Changing HW heat Element
08 George, have always used propane for hot water. Tried electric recently, flipped outside switch and no hot water. Shore power is 30 amp.
I know where the element is, is it easy to take out?
Ggantilla is offline   Reply With Quote
Old 04-21-2012, 10:13 PM   #2
Before you go to the trouble of taking the element out, maybe do a continuity check on it first. The problem may be elsewhere. If you haven't been using the element, it shouldn't be burnt out.
Old 04-21-2012, 10:20 PM   #3
There is a reset button on my hw heater. Round black rubber button on the face of the unit. Also check the power center where all the breakers are.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 04-21-2012, 10:25 PM   #4
Herk7769's Avatar
This may help.
1) Check the circuit breakers in the power center
2) Check the GFCI buttons on all outlets that have them
3) Check for voltage at the element under the round black cover.
Name:	AC diagram.jpg
ID:	12509   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 04-21-2012, 10:34 PM   #5
Good tips as always, thanks!
Old 04-21-2012, 11:09 PM   #6
bob213's Avatar
Great pictures here:
Webshots, the best outdoor photos!
bob213 is offline   Reply With Quote
Old 04-21-2012, 11:28 PM   #7
Mountainmanbob's Avatar
usually --- crud built up --- minerals ect
usually
not to hard to get out
although corrosion sure don't help
depending on the type of waters used
have seen many of these elements not last that long
had an elect on the rental up here years ago
we are on well water
had to replace them prox every 2 years
((much crud built up on element))
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 04-22-2012, 07:09 AM   #8
CLASS "A" Senior Member
cfsoistman's Avatar
If you need to replace it, HD or Lowes have the 120 Volt small elements for under $10. Way cheaper than the RV Dealers. They have the wrench as well to make it easy to remove.
Copper/Zinc Chromate Screw-in Electric Water Heater Element-15120 at The Home Depot
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-22-2012, 07:10 AM   #9
Herk7769's Avatar
YouTube Videos
This is an Atwood repair, but the Suburban is identical in procedure.
