Old 06-08-2013, 08:01 PM   #1
Changing over to golf cart batteries
This past week I replaced my ageing 12 volt house batteries with 6 volt golf cart batteries hooked in series. The ist thing I noticed is that the low voltage light on the jack controll didn't go on anymore. It may be my imagination but it seemed like the slides went in and out faster and the water had more pressure.
johnnypal is offline   Reply With Quote
Old 06-08-2013, 08:03 PM   #2
dcheatwood's Avatar
Beautiful rig.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-08-2013, 08:15 PM   #3
VinceU's Avatar
The Lippert low voltage alarm is very sensitive, the hyd pump would for sure run faster with more voltage. Four year old + lead acid batteries will lose capacity, think your obsevation were prably correct.....
Old 06-09-2013, 12:03 AM   #4
Iggy's Avatar
If you had bad batteries before that is why you probably got low voltages alot and the pump didn't turn as fast. New ones are full 13.6 volts total or more
Kind of curious on how you comapred the cold cranking amps from the two 12 volt batteries to two 6 volt batteries.
Usually the 12 volt batteries are 750-850 CCA.
What is it for the new 6 volts?
Name:	Motorhome Home 001.jpg
Old 06-09-2013, 05:05 AM   #5
Somewhat right of center
Crabbyguy's Avatar
Originally Posted by dcheatwood View Post
Beautiful rig.
I'll second that. Plus you live in Merrit Island.....I'm envious.
Crabbyguy is offline   Reply With Quote
Old 06-09-2013, 08:15 AM   #6
Great Horned Owl's Avatar
Starting batteries are intended to provide lots of current for a very short time. Deep cycle batteries are intended to provide much lower currents for a much longer time. Batteries that have a CCA rating are either starting batteries or hybrid (marine) batteries. True deep cycle batteries (i.e. 6V golf cart batteries) do not have a CCA rating. What you want to look at on these, is the Amp Hour rating.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 06-09-2013, 08:23 AM   #7
Iggy's Avatar
Joel
That is what I was thinking also. I just wanted to see how he decided on the specific amperage batteries he purchased to replace the old one lead acid.
Now we can talk about the advantage or disadvantages using lead acid or sealed deep cycle batteries in motorhomes
Old 06-09-2013, 10:19 AM   #8
Don't know much about batteries but do know the new ones are taller and much heavier.
Old 06-11-2013, 11:40 AM   #9
ronhanson's Avatar
Basically you want as many amp hours as you can get. The only limit is storage space for them.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 06-11-2013, 05:37 PM   #10
JimF's Avatar
You should also note that per the FR manual on the hydraulics it is stated very plainly that the slide should NOT be ran on the batteries alone, you should plug in to shore power or run the generator prior to activating the slides. The jacks must have the engine running.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is offline   Reply With Quote
