Old 02-16-2012, 12:55 PM   #1
Frank4's Avatar
Changing tire on georgetown
Have not need to do so yet. I would like to be ready in the event I would need to change the tire. I have a Spare underneath and have done it on cars an trucks before. Other than the tire I do not have any other equipment. Bought the motorhome used and need to find what I should have with me and the steps in the progress. Do I use the leveling jacks as the Jacks to raise the motorhome? Do I need to go to a truck stop store to by everything? Thanks for the help!
Frank4 is offline   Reply With Quote
Old 02-16-2012, 03:52 PM   #2
call road service
johnnypal is offline   Reply With Quote
Old 02-16-2012, 05:39 PM   #3
Jestercyco's Avatar
Frank4, I would never trust leveling jacks to keep that much weight up in the air and work on the tire. As johnnypal says, do not take chance wtih your or your families safety, call a professional.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 02-16-2012, 08:48 PM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
Road Service is by far the best answer to your question. They have the proper equipment to do the job correctly including torqueing the lug nuts.
We have Good Sam ERS and it covers quite a bit including all of your other vehicles for a little over $100 a year.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-16-2012, 10:24 PM   #5
Lottery Non-Winner
Ovair's Avatar
Besides, that big honkin' tire & wheel is going to be HEAVY!!!
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 02-16-2012, 11:11 PM   #6
Roy
Ditto on having road service change the tire. Have had three blowouts since we bought our 2004 Georgetown. Service trucks from Coachnet have always got the spare off from underneath the coach even though it's tricky since once the nut is taken off the long shaft......it drops...very dangerous!!!
All times it takes at least 2 people to get the spare up to it's original position.
Sometimes three hefty fellows even had difficulty getting it back up. A couple times the blown tire had to travel in the toad until we got to a tire shop and had them put it back up.
Hope the newer Georgetowns have a better system to lower and raise the spare .
Roy is offline   Reply With Quote
Old 02-17-2012, 08:33 AM   #7
bend302's Avatar
Road service is not that expensive and I wouldn't leave home without it. No way this old guy is going to wrestle one of those hulking tires.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 02-17-2012, 09:16 AM   #8
abjb's Avatar
They do, at least on our 2012.
There is NO spare.
As mentioned, one person probably wouldn't be able to get the wheel back on.
ab
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 02-17-2012, 12:18 PM   #9
cfsoistman's Avatar
Our Spare is in the trunk on the 2007 Georgetown 370. It is just a tire, no rim, so it has to be mounted on whichever rim has the flat. It's still a heavy tire even without the rim as well. It is the same tire as the other 6 though.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-17-2012, 06:12 PM   #10
Frank,
Go to < NMC | Roadside Assistance - RV Plans >. It will be the best $109 you ever spent. And your personal cars/pickups, boat trailers, etc., etc. are automatically covered too for no extra charges! And don't even think this kind of service from the "Good Sam" crowd.
Don Blake
07 Georgetown 349TSF
dpbbjc is offline   Reply With Quote
Old 02-17-2012, 07:50 PM   #11
abjb's Avatar
You should check with your local tire retailers.
A retailer (in Colorado) for a national chain told me they would not mount a tire that was over 6 yrs old.
This was for a 05 F250, happened in 2010.
Which brings up another problem. Your 07 MH probably has 06 tires.
ab
2012 Georgetown 360
Old 02-18-2012, 03:54 PM   #12
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
ab
Why is that a problem. I bought a 2011 378TS in August 2010 so of course it had 2010 tires. That's the way the RV industry works.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 02-18-2012, 11:02 PM   #13
abjb's Avatar
ab
When/if cfsoistman needs to have his 05, 06 or 07 spare mounted on a rim he may not be able to get anyone to mount it, it’ll be too old.
ab
2012 Georgetown 360
Old 02-19-2012, 04:40 PM   #14
nemo45's Avatar
ab
If I was selling new tires, I'd tell someone that we just can't mount those old tires. I think that's just BS. Lots of places sell and mount used tires. What about retreads the semi's use.
Old 02-19-2012, 06:02 PM   #15
cfsoistman's Avatar
I understand the statement where they might not want to mount an older tire and I hope I never have to have it done. This tire is in an enclosed trunk, has only seen the light of day before it was placed in there and once when I took it out to clean up all the stuff left from when the coach was built.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
