Old 08-20-2015, 06:54 PM   #1
RV Vagabond Jerry
Jerry Dixon's Avatar
Charge batteries while driving
While you are driving, does your engine charge the house batteries? If not, can you rewire it so it will?
Jerry Dixon is offline   Reply With Quote
Old 08-21-2015, 05:28 AM   #2
bubbles's Avatar
If you do not have the coach batteries disconnected then yes they will be automatically charged by the engine alternator. The chassis battery will have charging priority and once satisfied the coach batteries will be charged simultaneously.
Old 08-21-2015, 06:14 AM   #3
just make sure your battery sw is on
wire1946 is offline   Reply With Quote
Old 08-21-2015, 06:27 AM   #4
Herk7769's Avatar
The Georgetown, as with most if not all motorhomes, has a battery control center (BCC) that lets ANY available charging source charge all the batteries, house and starting.
There are current limiters (like fuses), an isolation relay (to prevent a depleted house battery from killing your starting battery), and a battery disconnect switch that can prevent the BCC from doing its job.
File Type: pdf Georgetown Battery Connect Center 113174 1 OF 1.pdf (318.6 KB, 91 views)
File Type: pdf BiDirectional Isolator Relay Delay.pdf (105.0 KB, 80 views)
HAM CALLSIGN - KC3FFW
Old 08-21-2015, 06:40 AM   #5
MarsMan's Avatar
Charging of chassis /coach batteries
This is excellent info. Anyone know if this also applies to coaches with the MBS chassis? If it does, this means my converter or my solar panels are also topping off my chassis battery? Not sure if this is considered a hi-jack of a thread or if related
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 08-21-2015, 06:47 AM   #6
Herk7769's Avatar
Since it is a motorhome (Class C) I am sure it has a similar system; but may be wired slightly different and the components may look different.
ID:	86406   Click image for larger version
ID:	86407   Click image for larger version
ID:	86408   Click image for larger version
ID:	86409   Click image for larger version
File Type: pdf Battery Control Center Information -1.pdf (1.34 MB, 53 views)
Old 08-21-2015, 09:31 AM   #7
MarsMan's Avatar
Thx. I will investigate and verify it applies to my MH. I hope it does. Would take a lot of the worry out of of storage/charging etc. I also have solar topping up my batteries
MarsMan
USN-R '01-present
Old 08-21-2015, 10:32 AM   #8
MarsMan's Avatar
I called coachmen. Yes their MHs all charge coach batteries off the chassis alternator. However they do not allow the MH charger to charge the chassis battery either via the genny or shore power.
Old 08-21-2015, 02:49 PM   #9
On a Lexington
On a Lexington class B+, which uses same chassis as class C, the generator does charge the house batteries. Can also charge with solar.
frogsandhogs is offline   Reply With Quote
battery
