Old 06-30-2014, 09:02 PM   #1
Charger question
I have a question that I think I have figured the answer to, but I want to be sure...
The house batteries were a little low, so I plugged in shore power. I was surprised to see little change overnight. Eventually I figured out that the disconnect switch needed to be on in the "connect" position order to charge.
Is this an accurate assumption, or do I have another problem to solve?
2014 Georgetown 335
WASOKI
We Are Spending Our Kids Inheritance
Jim Sullivan is offline   Reply With Quote
Old 06-30-2014, 09:48 PM   #2
I believe you are correct.
bmurph44 is offline   Reply With Quote
Old 07-01-2014, 01:04 AM   #3
You are correct. That disconnect switch does exactly that. Prevents discharge and charge, no pun intended.
Happy Trails, Forrest
Happy Trails
fbconsults
(Forrest and Donna)
2011 Georgetown 378TS
2011 Ford Escape V-6 4X4
fbconsults is offline   Reply With Quote
Old 07-01-2014, 06:44 PM   #4
bend302's Avatar
Wow! Really? I was sure that my convertor overrode the disconnect switch and fed 12V to the coach even with the battery disconnect off. I also assumed battery charging was taking place with the switch off.
Guess I'll have to do some investigating.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
