Old 03-27-2016, 08:30 AM   #1
Unhappy Check Engine Light Keeps Turning On
Hello All,
We bought our 2016 Georgetown 364TS just ove a month ago. On our way back home from picking it up we stopped for fuel and after about a mile back on the road the check engine light came on. I took it back to the dealer and they said I had to take it to a Ford Truck service dealer for check up. A friend of mine use an OBD scanner and the code said it was the gas cap. I re-tighten the cap but the light did not turn off. My friend cleared the code and the light turned off. This past week I went on a trip and I stopped for fuel and after about a mile the light came on again. Has any one had this type of issue?
Boricua_RVer is offline   Reply With Quote
Old 03-27-2016, 08:38 AM   #2
By any chance did you fill the gas tank with it running. Ford will tell you to make sure that you shut the engine off when filling. Also make sure you tighten the gas cap at least 4 clicks when installing it.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 03-27-2016, 08:38 AM   #3
RedLdr1's Avatar
Been there, done that... A bad, or loose, gas cap will cause a "Check Engine Light" (CEL). If you do not have a ODBII scanner to clear the code it will go away after a few engine restarts. Check your chassis Owners Manual for more info on how many restarts it takes. I think it is around 5-8 restarts to clear the code. If you have been tightening the gas cap and it is still causing a CEL I would replace the gas cap to avoid the aggravation....
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 03-27-2016, 08:48 AM   #4
abjb's Avatar
Haven't had the gas cap problem on the mh but have had it a couple of times on our toad. Clears after working (has to be tight) the cap and a COUPLE of start/stop motor cycles.
There are other problems that can cause this trouble code, purge valve, leaking vacuum line etc. Not going to hurt your motor it's an EPA thing.
It'll be covered by your Ford emissions warranty, you may have to take it to a Ford dealer that works on large Fords. Your dealer will know which one to take it to.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 03-27-2016, 09:52 AM   #5
The first time I had the generator running, but not the second time. That is why I am concerned.
Old 03-27-2016, 10:21 AM   #6
I Break Everything
mikel68's Avatar
Isn't it funny how the dealer has ALL the answers until you drive it off the lot. We had trouble with a front end alignment, which a lot do. When you call the dealer looking for that warm fuzzy feeling they were making you feel while looking/purchasing and you realize they really know nothing.
2015 Georgetown Forest River 351DS MH
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 03-27-2016, 11:20 AM   #7
Retired Retail/Importer
Check :Light On
I just sold my old RV and am about to buy a Forest River 360PDEK...It happened to me..I removed the positive lead to the engine battery and the light went off...it resets it...
pledbetter is offline   Reply With Quote
Old 03-27-2016, 11:54 AM   #8
I had the same problem with my new Sunseeker 3010DS with only about 1,000 miles on it. I thought it was the gas cap too but the light kept coming back on after I reset the code. I brought it to a Ford dealer and they found the evaporator for the emissions system was not working, after fixing the evaporator, the light has stayed off,
lucky55616 is offline   Reply With Quote
Old 03-27-2016, 12:21 PM   #9
SeaDog's Avatar
Invest in an OBE reader. Some codes which are called drivability codes (like gas cap) will reset by them selves after the problem is corrected and a certain number of engine starts 25-50. Using the reader you can clear the codes after correcting the problem.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 03-27-2016, 12:26 PM   #10
You really do not need a seperate reader. If you have a smartmphone, get the app Torque, buy an inexpensive ODBII dongle. You get not only a reader, but a great system monitor.
donniedu is offline   Reply With Quote
light
