Originally Posted by Swag
07 35’ George Town, with two sides.
22.5 tires max. Air is 110 lb’s.
How much should I run in rear tires.
There's a sticker behind the driver on newer ones that lists the weight as built and the recommended tire pressure. Hopefully you have it or it's somewhere else.
If you've never had it weighed, it's fairly easy to use a CAT scale at truck stops. While that will not get you the weight on each tire, just each axle, you can compare that weight to the sticker and see how difference there is. You should be loaded up with full fuel, supplies, bodies and however much fresh water you usually carry.
Split the difference on each axle and add 5% because of left-right imbalances and that should get you pretty close.
Mine with a 22,000 lb. chassis has a sticker of 90 lbs on all tires so I bump them up to 95 lbs. for a slight margin and to give the TPMS more room to react to a leak. The tires are 110 max as well.
FWIW,
Ray
