Old 06-05-2019, 08:01 AM   #1
Checking tire pressure
Looking for a fix to check air pressure on outside rear dual. Canít get the gauge between the duals and no way to air up. Any help would be appreciated. Thanks
coffeegrinder is offline   Reply With Quote
Old 06-05-2019, 08:32 AM   #2
Do you have the gauge with the angled head?
DYNAMAX 2016 FORCE HD
houstonstroker is online now   Reply With Quote
Old 06-05-2019, 08:48 AM   #3
Do you have a gauge like this one? (below)
It is what most truckers use. (and a lot of other folks too!)
The second one is an inflater/gauge.
Days Camped: '16=46 '17=30 '18=51 '19=18
Old 06-05-2019, 10:22 AM   #4
DaGrinch's Avatar
Do you have a picture of what you are talking about? Sometimes the valve stems of the inner dual can be a bear if there's no extension or the supplied extension isn't properly installed, as was a case I had.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is online now   Reply With Quote
Old 06-05-2019, 10:30 AM   #5
bubbles's Avatar
I thought all GT's came with valve extensions on all rear duals. Might want to check with dealer.
Old 06-10-2019, 02:56 AM   #6
Mr. October's Avatar
I added solid extensions to mine. Otherwise the angle of the stem took it too close to the rim and it was difficult to get the gauge or air chuck on mine.
Pete Githens
Reading, PA
Formerly - 2007 Itasca Navion (Sold and gone)
2019 Georgetown GT5 31R5
Mr. October is offline   Reply With Quote
Old 06-10-2019, 11:22 PM   #7
07 35’ George Town, with two sides.
22.5 tires max. Air is 110 lb’s.
How much should I run in rear tires.
Swag is offline   Reply With Quote
Old 06-11-2019, 12:09 PM   #8
Originally Posted by Swag View Post
07 35í George Town, with two sides.
22.5 tires max. Air is 110 lbís.
The only way to know how much air pressure to put in your tires is to weigh each axle fully loaded then compare that info to the tire manufacturers air pressure chart. You should also weigh each tire. (Front right, front left, rear right, rear left to also know if you are properly balanced)
I have a 2013 378XL on a 24,000lb chassis and I run 3 lb more air pressure than the chart recommends. Front tires are at 83 PSI and rear tires are 87 PSI. My axles are: Front axle weight 7300# and rear axle 15,500#.
My dealer put 105PSI in them when I bought it and it rode very hard.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 06-11-2019, 06:22 PM   #9
NXR
There's a sticker behind the driver on newer ones that lists the weight as built and the recommended tire pressure. Hopefully you have it or it's somewhere else.
If you've never had it weighed, it's fairly easy to use a CAT scale at truck stops. While that will not get you the weight on each tire, just each axle, you can compare that weight to the sticker and see how difference there is. You should be loaded up with full fuel, supplies, bodies and however much fresh water you usually carry.
Split the difference on each axle and add 5% because of left-right imbalances and that should get you pretty close.
Mine with a 22,000 lb. chassis has a sticker of 90 lbs on all tires so I bump them up to 95 lbs. for a slight margin and to give the TPMS more room to react to a leak. The tires are 110 max as well.
FWIW,
Ray
NXR is offline   Reply With Quote
check, pressure, tire
« Fuses | Awning »
