Old 07-25-2010, 12:43 PM   #1
Checking tires ???
On our Georgtown341ds, it appears that there is one valve stem protruding from the center of the rim on the dual wheels. How do you go about accessing the valve stem (to check pressure) on the inner tire? Or, as I suspect,, is it a case of crawling around on the ground to get behind the outer wheel?
Gator_38 is offline   Reply With Quote
Old 07-25-2010, 02:05 PM   #2
NWJeeper's Avatar
I use a dual head chuck on an air inflator/gauge similar to this.
Ed & Wendy
www.nwjeepn.com
Old 07-27-2010, 08:11 AM   #3
I own a dually and one of my HUGE peaves whenever I have tire work done is making sure the outside wheel is clocked correctly to allow me access to the inside wheel's valve stem. There is only ONE clocking position on my truck that allows access to the inside valve stem unless you are double jointed and Über skinny. You may just have a clocking issue and need to remove the outer wheel and turn it until access is easier.
aintgotnun is offline   Reply With Quote
Old 07-27-2010, 04:34 PM   #4
Los Popes's Avatar
I had my dealer install valve stem extenders - makes it very easy to check air and refill.
Bubba & Chiquita + Two Vizslas (Barley and Sophie)
2008 Georgetown 315DS SE LTD
2011 Jeep Wrangler Unlimited Rubicon
Sterling All-Terrain Tow Bar - SMI Stay-In-Play Duo
Do What You Like - Like What You Do!
Los Popes is offline   Reply With Quote
Old 07-27-2010, 08:20 PM   #5
milzat's Avatar
Camco 44913 RV Dual Wheel Valve Stem Extender for 22"…
http://www.wheelmasters.com/inflators.html
milzat is offline   Reply With Quote
