Old 07-26-2015, 02:33 PM   #1
Chesapeake Bay Bridge Tunnel
Arrived yesterday in our '14 377XL for a week at Toms Cove on Chincoteague for the annual Pony Penning. As usual no problems whatsoever!! But, while going through the tunnels one of the AC shrouds hit the ceiling of the tunnel probably 5 or 6 times . Not hard enough to do any damage, but somewhat disconcerting none the less. This happened in both northbound tunnels. Has anyone else had this happen ??
DennyH is offline   Reply With Quote
Old 07-26-2015, 03:25 PM   #2
Lloydg's Avatar
Copied this from the attached link; How tall is your rig?
Chesapeake Bay Bridge-Tunnel -- GATED LANES
Both of the tunnels can only accommodate a maximum height of 13’6”. District personnel have to inspect and measure any vehicle over that height requirement so that the driver can be turned around or properly adjust the height of the truck. Typically, this happens about 15 times per day. Allowing a truck to go unchecked is not only a safety issue but could also be very expensive.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 07-26-2015, 03:55 PM   #3
Our rig is a stock 377XL
Old 07-26-2015, 06:07 PM   #4
GABoy's Avatar
You sure it wasn't the radio antenna hitting the tunnel ceiling occasionally? Seems like it would have damaged ac shrouds or more if direct hit. Our antenna goes another foot higher than shrouds.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 07-26-2015, 10:34 PM   #5
I thought that your propane tank would be restricted in the tunnels...
happywhencamping is offline   Reply With Quote
Old 07-26-2015, 11:26 PM   #6
Propane tanks are not prohibited. The requirement is they be shut off.
Old 07-27-2015, 01:53 PM   #7
The bridge tunnels are 13'-6"
Ultraboy is offline   Reply With Quote
Old 07-27-2015, 01:57 PM   #8
I was reading in GS directory and I got the impression you could'nt go through tunnels with LP. Was I reading it wrong.
Myrle is offline   Reply With Quote
Old 07-27-2015, 02:24 PM   #9
You can go through tunnels but LP must be turned off. We are always ask by the toll attendants if our gas is shut off.
Old 07-27-2015, 03:43 PM   #10
jkoenig24
There's a tunnel (or two) in the Baltimore area that allow ZERO propane. There'a also a tunnel (or two) in the Virginia Beach area (other than the Chesapeake Bay Bridge Tunnel) where you MUST stop and have a uniformed municipal employee manually check / ensure that your propane is turned off before using the tunnel.
jkoenig24 is offline   Reply With Quote
