Old 07-31-2014, 08:46 PM   #1
Chevy silverado as a toad
Does anyone know the requirements to tow a chevy Silverado 1500 4wd as a toad? Does it require any fuses to be pulled or any special requirements? What tow bar would you suggest I use?
2012 Gerogetown 337XL
Tow Dolly
DW of 24 Years.
Hope to meet you on the trail.
ejw7213 is offline   Reply With Quote
Old 07-31-2014, 09:09 PM   #2
Look in the manual. I can put the electronic transfer case in neutral and tow mine 4 down. You should be able to also. Doesn't spin the transmission that way. I don't know about a tow bar, you need one to handle the truck's weight.
POS Camaro is offline   Reply With Quote
Old 07-31-2014, 11:27 PM   #3
Krazymace's Avatar
I'm guessing that truck exceeds the 5000# threshold of all our GT.
Krazymace is offline   Reply With Quote
Old 08-09-2014, 10:47 PM   #4
A diesel pusher is the only MH I know that can tow a vehicle that heavy.
nicholsonv is offline   Reply With Quote
Old 08-09-2014, 11:15 PM   #5
Krazymace's Avatar
If it's rated over 5000lbs
Old 08-11-2014, 05:44 PM   #6
gspage53
gspage53's Avatar
Send a message via Yahoo to gspage53
Yeah, I went to Camping World in Chattanooga to see about towing my Ford F-150, even at its lowest weight of 4860 pounds, CW nixed the idea. Too close to the 5k limit.
Stan and Patti
2014 Georgetown 351DS
gspage53 is offline   Reply With Quote
Old 08-12-2014, 08:26 AM   #7
kenandterry's Avatar
ejw7213
The issue here is the weight of the tow vehicle you are inquiring about. All of us who own Georgetowns, regardless of the different modesl, are probably equipped with the same towing hitch, which is limited to 5000 lbs. And that doesn't address the fact that a lot of people tend to also load the tow vehicle with "stuff" almost like a trailer.
You might really need to review your choice of tow vehicle for your motorhome. Most brands these days are Ford chassis with the same limitations.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
toad
