Old 07-13-2015, 10:59 PM   #1
Chrome caps on rims.
I'm pretty sure that this has been asked & answered but I did not find it. So how do you remove the chrome caps that cover the nuts that hold on the chrome cover, do remove these or do you just use a socket and ratchet to remove. Thanks to all for helping with all sorts of little problems we all have.
kdcamper 2014 Georgetown 377XL
kdcamper is offline   Reply With Quote
Old 07-13-2015, 11:22 PM   #2
Berkshire 390QS
NO3putt's Avatar
There are two of the nuts that have a little dimple on them, those are the ones to remove. The dimple is at the base of the nut. Our Berkshire came with a T type handle the fits the nuts.
Old 07-13-2015, 11:52 PM   #3
Iggy's Avatar
Hopefully you have the 22.5" rims and not the 19"
I believe we have 2 that have a notch on them that are pulled off and the rest are dummy's. See attachment.
Old 07-14-2015, 08:13 AM   #4
Yes I have the 22.5" rims so I will that a shot thanks again.
kdcamper
Old 08-22-2015, 07:24 PM   #5
ron377ts's Avatar
Pretty sure there are 3nuts with dimples.
ron377ts is offline   Reply With Quote
Old 08-22-2015, 07:36 PM   #6
Krazymace's Avatar
Mine does.
Krazymace is offline   Reply With Quote
Old 08-22-2015, 08:13 PM   #7
I believe it may just be the 19.5 inch wheels on the regular Georgetown that has the 3 nuts with dimples. I have the 19.6 inch and it has three also.
Wayne & Pat
2014 Georgetown 328TS
2013 Chevy Sonic Hatchback
Houston, Texas
WayneT is offline   Reply With Quote
Old 08-22-2015, 08:18 PM   #8
Also, depending on how tight they are on the T handle tool may not be enough to get them off. I had to use a 1 1/8 socket with a small breaker bar to loosen them the first time.
Wayne & Pat
Houston, Texas
Old 08-23-2015, 08:19 AM   #9
RANGERBOB's Avatar
I had this pointed out when I was at a tire shop while the tech was removing a leaking valve extender. Had an inside dual almost go flat in Moab,Utah. He told me it was a common problem they see. I now go to the hassle of removing the chrome wheel covers to check pressure. It beats the thrill of a flat.
RANGERBOB is offline   Reply With Quote
