Old 05-24-2013, 08:56 AM   #1
City water
I am hooked up to city water but the system keeps using up the fresh water tank. Would turning off the water pump solve this?
SaladoBob is offline   Reply With Quote
Old 05-24-2013, 08:57 AM   #2
vizsla owner's Avatar
If you are on city water you can turn the pump off. The pressure from the city water should send it through your lines.
03 Forest River Salem LE Travel Trailer 26BHSS
'12 Chevy Suburban w/ Heavy Tow Pkg
4 kids: G13, G12, G10, B6
2 Vizsla's Mizuno & Zeno, 1 Weimaraner Kayda
2013 Nights Camped 7
vizsla owner is offline   Reply With Quote
Old 05-24-2013, 09:01 AM   #3
Thanks. I will give it a shot tonight.
Old 05-24-2013, 09:06 AM   #4
Dave_Monica's Avatar
You should also have a pressure regulator on the incoming city water line to control pressure in the 40 - 50 psi range.
Dave
Old 05-24-2013, 09:13 AM   #5
Dave
That I do have. New to this and learning every day. Thanks
Old 05-24-2013, 09:20 AM   #6
bend302's Avatar
It has been my experience that if the city water pressure is less than the pump PSI, the pump will run and draw water from the fresh water tank. Before I bought a "better" pressure regulator, we found that we had more shower pressure with the pump. Then, I upgraded to the higher flow unit and the pump doesn't run even if it is turned on.
Based on that, I ass-u-me the better city water pressure overrides the pump.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
