Old 03-04-2014, 02:53 PM   #11
Originally Posted by Iggy View Post
Being you have a new Georgetown I would have the generator checked by the dealer under warranty.
It sure sounds like the generator speed is the problem. If you have any accurate voltmeter I would for now check to see what your generator output voltage is. Should be 115-120 volts.
Let us know what you find out.
Good luck
Voltage is good it is 118
kgreen is offline   Reply With Quote
Old 03-04-2014, 03:11 PM   #12
camaraderie's Avatar
Your clocks are probably synched to a VERY stable household current CYCLE of 60HZ...generators are often unstable in this...but only the clocks notice!
camaraderie is offline   Reply With Quote
Old 03-04-2014, 03:25 PM   #13
Yes not that big of a deal I was just wondering why & now I know thanks to everyone
generator
