Old 03-02-2014, 07:44 AM   #1
Clock with generator
Why do my clocks run about 30 min ahead in about 7-8 hours with generator running
kgreen is offline   Reply With Quote
Old 03-02-2014, 08:01 AM   #2
jriddering's Avatar
Most AC clocks maintain time off 60 cycle frequency. Generator is running at more than 60 cycles. Get a clock that auto sets time from the air.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 03-02-2014, 08:26 AM   #3
Or...get generator set to 60 HZ!
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 03-02-2014, 08:48 AM   #4
jriddering's Avatar
That will work too. generator might be able to be adjusted a little closer to correct speed.
Jim and Carol
Old 03-02-2014, 11:56 AM   #5
leomosley's Avatar
I believe that power utilities adjust their output frequency to average 60 Hz (IE: if it runs over for a bit, it will run under to average out), so that clocks will maintain the correct time. Your generator attempts to maintain 60 Hz, and therefore could average under or over over time
Sent from my ME173X using Forest River Forums mobile app
Cheers
Leo Mosley
2011 Georgetown 300S
leomosley is offline   Reply With Quote
Old 03-02-2014, 02:30 PM   #6
Iggy's Avatar
If your clocks are run off of a motor then the frequency would effect it.
It shouldn't effect any electronic clocks like in the microware.
Sounds like you have more than one clock that is doing it.
What clocks in the motorhome are you talking about?
Old 03-02-2014, 03:10 PM   #7
The microwave clock & I had a coffee maker plugged in the next morning both clocks had same time which was about 30 min ahead of the time I reset them to correct time as day went on they were both gaining time
Old 03-02-2014, 03:30 PM   #8
Iggy's Avatar
Being you have a new Georgetown I would have the generator checked by the dealer under warranty.
It sure sounds like the generator speed is the problem. If you have any accurate voltmeter I would for now check to see what your generator output voltage is. Should be 115-120 volts.
Let us know what you find out.
Good luck
Old 03-02-2014, 05:43 PM   #9
Good luck
I will check voltage & see if it is ok
Old 03-02-2014, 05:49 PM   #10
jriddering's Avatar
You could be within the correct voltage and have cycles per second still off. I get it at home when running off generator when we lose power. I just know it will be off and reset it as needed
Jim and Carol
generator
