Old 08-24-2011, 07:35 AM   #1
Coach Batteries
My coach batteries slowly lose their charge while I am on external 50 amp service. The coach batteries only fully charge when charged off the engine alternator. I have run the generator for 4 hours and the coach batteries get to 75 percent charged. Any ideas what this may be an early symptom of?
MikSher is offline   Reply With Quote
Old 08-24-2011, 07:58 AM   #2
Sounds to me like your converter, that charges the batts when you are on shore power is loosing it..have the output of the converter checked. The other reason may be that you have old batts and they are sulfated. Old batts are hard to charge and the alternator on the engine puts out a hefty amount but the converter does not thus...the batts get a better shot with the alternator. My money would be on your converter not working properly.
polkatronron is offline   Reply With Quote
Old 08-24-2011, 09:00 AM   #3
TURBS's Avatar
I'm with polkatronron!
possibility of weak or bad charger and bad batterys.
depending on how many batteries you have and how low they are it may take days to charge with a good charger.
Most coaches have an inverter / charger.
I just put one in my employer s coach for same reason.
$1,000 bill
Old 08-24-2011, 09:48 PM   #4
I just had converter checked and it is the problem. Thanks for the help.
Old 08-25-2011, 10:36 AM   #5
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Wondering what converter you have? If its a Parallax I'd replace it with an Intelli-Power PD4655. Its a direct replacement for the Parallax and has a much better 4 stage charger (charge wizard). You can look at them at bestconverter.com. Only runs $205. I'm going to replace my Parallax soon and mine is working ok. These 4 stage chargers are much better for your batteries.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 08-25-2011, 08:01 PM   #6
Thanks for the suggestion. I will do my homework through best converter web site.
battery
