Old 10-22-2014, 08:53 PM   #1
Coach battery Charge??
Can anyone tell me if the coach battery charges off the house converter when plugged in and parked??.. I'm not planning on taking a trip for a few month and wondering if I need to hook up a separate battery tender for the coach battery.....
Thanks in advance..
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 10-22-2014, 09:04 PM   #2
Mine does
mark10361 is offline   Reply With Quote
Old 10-22-2014, 09:18 PM   #3
Sounds like you got it nailed. Yes.. it does, but I wouldn't leave them charging/floating on the coach converter. Once it's at full charge, shtick it on the battery tender.
Or if you want to save a few bucks, plan on around 15% SOC off-gassing every 30 days or thereabouts. Just give them a good charge up every 30-45 days and you're fine.
Battery tenders are great for no-brainer long term storage, but having to run your battery back up every 45 days is a good reminder to check your water levels (if you're using wet cells). It doesn't happen much, but even a battery tender can act up on you and cook your cells.
rana is offline   Reply With Quote
Old 10-23-2014, 07:28 PM   #4
Thanks ..Appreciate the Info..
Old 10-27-2014, 01:27 PM   #5
bend302's Avatar
My coach is a few years older but I found the onboard charger tended to boil the batteries dry after a week or so.
However, if I stay hooked to shore power in FL for 3 months and constantly use DC power, I have no issues. Not sure I understand that. I do water my batteries with a remote watering system monthly.
Regardless, I leave mine on a battery tender all the time between trips.
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
