None at all that I can think of. In storage the converter is going to be delivering minimal power to the 12 VDC side so its AC current draw will be similarly reduced.
A 70 amp converter delivering 70 amps at 12 VDC will be pulling 7 amps at 120 VAC if it is 100% efficient, which it isn't but I doubt its worse than 90% efficient.
The Converter breaker probably is a 15 amp so you should have plenty of capacity for a couple of hundred watts of extra heat. Just be sure to check the Converter breaker size; I don't have access to mine because a dog is sleeping in front of the panel right now.
Even though you blew out the lines, it may be a good idea to pump antifreeze through the entire system including the toilet(s). I've read too many sad tales where people had a tiny amount of water remaining in their toilet flush valves and they found them cracked in the Spring. I have a Tecma macerating toilet in the middle bath and there's no way I would take a chance with something inside that thing freezing and breaking.
Ray
