Old 11-10-2014, 10:13 AM   #11
Originally Posted by chrisbailey13 View Post
Interesting dilemma, even when I disconnect the battery, my Step still works. I think mine is either wired before the disconnect or it is wired to the starting battery.
In my case my step will NOT stay out if the battery disconnect is pressed even if the switch is set to do so.
What model coach do you have?
378
georgetown50 is offline   Reply With Quote
Old 11-10-2014, 10:17 AM   #12
Originally Posted by CSMRetired View Post
If I can explain this correctly. ....it will work
shut the screen first
Reach in through the slide handle and switch off the battery disconnect
Close the main door
Hopefully I explained that correctly
I understand what you are saying but I think you may have left out the Entry Step switch. Don't you have to turn that switch up before you disconnect the battery?
Old 11-10-2014, 10:21 AM   #13
Originally Posted by bend302 View Post
My steps will retract when I turn on ignition key regardless of batty disconnect and will always deploy when door is opened. Assume it's a safety thing to stop dummies like me from driving off with steps deployed or stepping into thin air.
Bill
Yes, it is a safety precaution. 90% of the time, having the steps out once parked makes perfect sense. But I will have my rig in a storage facility where someone could back up right next to my RV. I don't want to take the chance of them hitting the entry step while backing up.
Old 11-10-2014, 11:57 AM   #14
chrisbailey13's Avatar
When you say "Disconnect the battery" are you referring to using the battery disconnect switch, or actually removing the terminals from the battery post.
As mentioned earlier, My steps continue to extend and retract even when the battery disconnect switch is engaged(disconnected). so when I disconnect using the switch, my steps still retract when the door is closed.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 11-10-2014, 07:21 PM   #15
Send a message via Skype™ to Falcon35
On my 378 with the Lippert steps it would do what you say and I would use the magnet or reach in through the screen door to turn of the disconnect. After Forest River put on the Kwikee steps and the new magnet I can turn off the battery disconnect and close the door and the steps go in.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 11-12-2014, 02:25 PM   #16
WDK
WDK's Avatar
Simply take the magnet off the screen door, place it next to the sensor with a piece of good tape. The steps will retract. You can then kill the power. I do that as well when I store mine as if someone does park next to me my steps will open and perhaps hit their rig.....if that situation were to happen....I just open the door as much as needed to get inside....start it up...pull my coach out to clear any obstruction and pull the magnet from the sensor after turning the batteries on. The steps will extend....I put the magnet back on the screen door and all is normal again.
WDK
WDK is offline   Reply With Quote
Old 11-12-2014, 10:29 PM   #17
Dijoeboss's Avatar
I have had the steps on my rig do whatever they want - when they want. I've had to go so far as to disconnect the motor on the steps to keep them down while camping because no matter what I tried, they would always retract when the door was shut. Have had a Rv dealer check it out twice, of course they work normal then! When storing, I have to reach in thru screen door, trip disconnect switch and then close the main door.
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 11-12-2014, 10:39 PM   #18
Iggy's Avatar
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Sound like the screen door magnet isn't strong enough or the screen door moves a little and opens the contacts and the steps will go out.
It's just a basic switch on the screen door.
It also comes in when the engines is started.
Iggy is online now   Reply With Quote
Old 11-13-2014, 06:17 AM   #19
bubbles's Avatar
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
If you have the Lippert steps and are wired correctly then the step power switch (not coach disconnect switch) is only for retracting the steps when set to on (should be off when camping to keep steps out with door closed). I think I read where the Kwikee step power switch does just the opposite when set to on. Both step systems however will retract with ignition switch whether step power switch is on or off.
Old 11-13-2014, 12:02 PM   #20
Assuming your batteries are under the steps like most GT's what I do (just Tuesday) is loosening the nuts on the negative battery terminal, go inside the RV and close the door. Steps are retracted, I just reach down and take off the negative wire. No battery power, no moving steps. Open door, jump out and continue to remove batteries.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
fuse
