Old 11-09-2014, 10:14 AM   #1
Confused on the entry step
I'm putting my Georgetown in storage and I'm trying to get my entry step to stay in after disconnecting the house batteries. I can not seem to get the steps correct in making this happen. Maybe I should't worry about this but I don't want someone parking next to me to hit the entry step so I would prefer to have it stay in but it doesn't seem to want to do this after I have disconnected the batteries which I know I need to do when storing the RV.
Can anyone explain the correct procedure? I know I need to engage the entry step switch but when I do this and disconnect the battery, it still stays out.
Thanks in advance.
georgetown50 is offline   Reply With Quote
Old 11-09-2014, 10:54 AM   #2
CSMRetired's Avatar
If I can explain this correctly. ....it will work
shut the screen first
Reach in through the slide handle and switch off the battery disconnect
Close the main door
Hopefully I explained that correctly
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 11-09-2014, 01:03 PM   #3
kenandterry's Avatar
georgetown50......
Your signature doesn't mention what model of rig you have.
CSMRetired....
Your procedure does not work for everyone depending on the location of the switch for the battery disconnect, and it's proximity to the door. Mine for example is too far away to reach through the opening for the slide handle.
The solution for everyone's rig, (with both doors open) is to place a magnet near where the magnetic sensor is for the part on the screen door inside the step well. This should "fool" the steps into thinking the screen door is closed, and retract the steps. Then removal of the house batteries can be completed.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 11-09-2014, 06:52 PM   #4
chrisbailey13's Avatar
Interesting dilemma, even when I disconnect the battery, my Step still works. I think mine is either wired before the disconnect or it is wired to the starting battery.
In my case my step will NOT stay out if the battery disconnect is pressed even if the switch is set to do so.
What model coach do you have?
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 11-09-2014, 06:54 PM   #5
So, clarification question....if you are inside the coach with the door closed, and you hit the battery disconnect, what happens when you open the door?
Old 11-09-2014, 09:02 PM   #6
abjb's Avatar
Lawyers earn their pay.
I did a search on "magnet"...enjoy.
Forest River Forums - Search Results
I didn't use the magnet method,
Controlling steps
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 11-09-2014, 09:30 PM   #7
coupevillefish's Avatar
I have 2 circuits that are not connected through the battery disconnect - lb detector and steps. If I have the power off (a/c unplugged) and the step control in the correct position, my steps will retract.
coupevillefish is offline   Reply With Quote
Old 11-10-2014, 06:55 AM   #8
Originally Posted by kenandterry View Post
georgetown50......
CSMRetired....
X2
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 11-10-2014, 09:15 AM   #9
bend302's Avatar
My steps will retract when I turn on ignition key regardless of batty disconnect and will always deploy when door is opened. Assume it's a safety thing to stop dummies like me from driving off with steps deployed or stepping into thin air.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 11-10-2014, 10:12 AM   #10
I have the Georgetown 378.
fuse
