Originally Posted by flexdogScott
Hello Georgetown owners -
We are considering purchasing a new 2018 or 19 Georgetown 369XL.
Couple questions:
1. I saw a thread that said in 2015 there were separate gray and black tanks for the front and rear of the coach. Is this still the same? Do they drain together? Does the black wash-out hit both of the black tanks? There was also a note that the rear tank had some piping that was up inside the storage bins so that it was inaccessible?
2. is there anything specifically that we should check out before we buy one? Any specific changes from 2018 to 19 that are worth mentioning?
3. Have you been happy with this floorplan and the quality of the coach construction?
Thanks!
-scott
Hi
We have a 2018 369. Just finished a 5 week trip to snowbird in Florida. My wife and I like to say the things we like far outweigh the things we don’t
1) yes separate black and grey. (2 black 2 grey)The kitchen area sink and 1/2 bath black tanks empty in a center area compartment where the water and filter are. The main bath in rear black and grey empty in the compartment just forward of the electric.
2) I can’t speak to changes from 18 to 19
3) although we do like the floor plan a lot there are some WWTT ( what were they thinking issues). The TVs for example are all permanent attached. I had to unscrew the main tv to add HDMI connections. Crazy. The bedroom is the same as well as outside. DVDs are played from the dash and all wiring feeds from there to the TVs they should have added an HDMI connector. Read the forums here there will be more on thins.
Lots of “not so great workmanship”. After one trip we found the hanging strip for clothes in the first closet pulled off. OK we may have overloaded it but if you see the screws they used....yikes. I reattached that and fixed the others as well with firmer and more screws.
Be prepared for other minor things that you can fix yourself if on the road.
Don’t let me scare you though.......as I said the good far outweighs the bad and we shopped for this type of floor plan for awhile. Enjoy it
