Old 06-30-2015, 12:53 AM   #21
camaraderie's Avatar
Originally Posted by Vince and Charlette View Post
I must be missing something. Bought 2015 GT 364TS in Jan and have put on 6,000 miles. Coach is fantastic! But, the chassis F53 is pitiful. It's worth repeating the big three problems I've addressed before: power, i.e. torque is sad. I spend a lot of time at or near 5,000 rpm just to maintain speed even on the smallest hills. Engine noise is incredible. Can't carry on a conversation without yelling when you're at higher rpm. Worst of all is sway. So far, I've spent $2,600 trying to deal with it...tracbar, steering stabilizer, wheel alignment and rear anti-sway bar. All this netted little improvement. The two most common responses I get are: "Get over it" and "If you wanted power, low noise and a stable vehicle, you should have bought a DP. Like I said, the coach is great, better yet, we're still debt free!
Since every gas class A in all brands is built on this chassis and engine... I'm thinking that it is not a meaningful decision point on choosing a Gtown vs. an FR3 or other major brand gqsser. I don't have the RPM problems you describe..or the sway...but the latter is probably chassis length related.
Good luck getting to the bottom of your issues.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-30-2015, 08:26 AM   #22
look closely at position of fuses
Originally Posted by fdp View Post
Considering upgrading from a FR3 to a Georgetown and would like opinions and experiences. Would you buy a Georgetown again or buy a another manufacture
FDP
05 gtwn 375 xl TS I bought one would not do it again fuses are next to batteries under stairs open to SALT cabinet is loose even after I replaced 80 lb old tv
glenn56h is offline   Reply With Quote
Old 06-30-2015, 09:21 AM   #23
New:
compman69's Avatar
Originally Posted by Iggy View Post
On a flat road with out a headwind I usually run 2000 to 2200 rpms and that relates to about 65 mph. If you are getting anything different I would think the engine needs to be checked by Ford.
At 60-65 mph my sound level is reasonable.
I did see that the dog house on the 2015 is bare. Mine is covered with carpet and that may be what makes mine a little more reasonable with engine noise.
Now you also know that your car plus fuel and cargo could me maxing your 5,000 lb tow rate. Not to mention your motorhome cargo, fuel, etc.
Just some information to help you.
Good luck
My 328ts has a padded doghouse. The noise level is not bad unless I really have my foot in the carburetor, I have thought of putting Dynomat on the underside for heat and noise.
I did agree that the battery box is open to the outside. I am going to look into a mud flap or something to help deflect some of the water.
I do spray it down with fresh and clean the area when I am washing the rig.
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
compman69 is offline   Reply With Quote
Old 06-30-2015, 09:54 AM   #24
open fuses
I am having a cover fabricated for fuse block as to the batterys will put them in boxes bolted ( ss) to bottom
in south they use a SALT SOLUTION not just salt
replaced ALL fuses sprayed contact cleaner still have shorts
Old 06-30-2015, 09:58 PM   #25
Vince and Charlette's Avatar
Compman69, Is the padded doghouse OEM or an add-on? I'd sure like to put my hands on a pad like that.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 07-01-2015, 07:09 AM   #26
fuse block cover custom built marine fiberglass by my sons friend
quite an undertaking (lots of swearing) you have to drill a hole and tap the steel beam also
Old 07-06-2015, 04:56 PM   #27
New:
compman69's Avatar
The Padded Dog house is standard on the 2015. The only carpet on my coach is next to the bed on the rear of the coach. I haven't figured that out since there is no carpet anywhere else. I can take a pic if you would like and post since I am heading out soon!
Old 07-06-2015, 05:08 PM   #28
Here's a pix of mine...2015 model.
Name:	2014-07-09 16.38.56.jpg
________
Cam
Old 07-06-2015, 05:44 PM   #29
New:
compman69's Avatar
Pretty much the same as mine!
Congrats Camaraderie!
Old 07-06-2015, 06:58 PM   #30
Thanks...had it about a year now...still breaking it in!
Good luck with yours...nice layout!
________
Cam
georgetown
