Old 09-25-2012, 01:39 PM   #1
Converter/Charger to battery voltage
I have a question about the amount of voltage drop that would be considered normal between the Converter/Charger output terminals and the input terminals of the BCC. I see 13.68 volts at the Converter/Charger output terminals and only 12.07 volts on the input terminal on the BCC. Is this normal or is there something between the two that could cause a drop of this much?
wmm1955 is offline   Reply With Quote
Old 09-25-2012, 05:53 PM   #2
Tim & Lisa Trempert
Sorry about my ignorance, but what is a "BCC"?
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 09-25-2012, 06:00 PM   #3
BBC = Battery Control Center usually located near the coach batteries.
Old 09-25-2012, 06:34 PM   #4
Tim & Lisa Trempert
I would think the voltage would be the same if you are measuring it on the input side of the BCC
Tim & Lisa
2011 Georgetown 350
Old 09-25-2012, 06:53 PM   #5
TURBS's Avatar
There is no 12 volt input voltage on the converter so im not sure what your trying to measure .
the input to the converter should be 110v ac the output voltage should be dc voltage .
please explain .
Turbs
Old 09-26-2012, 12:45 PM   #6
The 12 volt input I am referring to is the one coming from the converter/charger which ends up going to the 12 volt inpur side of the BCC.
Old 09-26-2012, 12:50 PM   #7
TURBS's Avatar
Gotcha.
In theory it should be the same.
What is voltage at your batteries?
Old 09-26-2012, 01:05 PM   #8
I figured that as well, that they should be the same. The voltage at the battery is the same as it is at the BCC(12.07). I think I may have found the problem. There is a little black box mounted to the frame that the power wire from the converter is attached to on one side and then goes to the input side of the BCC. I have 13.68 volts going in, but not coming out the other side. The other side has the same voltage as the battery. I believe the little black box is a circuit breaker of some type, that may not be functioning correctly. Won't have a chance to do some more testing until later.
Old 09-26-2012, 02:14 PM   #9
TURBS's Avatar
Sounds like your on point !
Update when u can.
Turbs
Old 09-26-2012, 03:43 PM   #10
Herk7769's Avatar
Here is the wiring diagram for the BCC and it might help you find the fuse/current limiter that is open.
File Type: pdf BiDirectional Isolator Relay Delay.pdf (105.0 KB, 43 views)
HAM CALLSIGN - KC3FFW
battery, voltage
