Old 07-08-2012, 11:57 PM   #11
The igniter on one of my burners was not sparking. Just fixed it tonight. The curved metal tip on the outside of the burner must have bent when cleaning the stove (probably got snagged on a rag). I simply pushed on the curved metal ignitor tip just slightly to make the gap a little less between the tip and the white ceramic recess that holds the tip. Works great now. Will try to remember to take a picture next time I go out to the RV storage lot.
blightle is offline   Reply With Quote
Old 07-11-2012, 09:33 PM   #12
ME
sparks1032's Avatar
My turn knob broke off! The shaft cracked and does not even turn when forced on I am thinking some epoxy and let it ride
2008 Georgetown 350TS
sparks1032 is offline   Reply With Quote
Old 09-17-2012, 09:12 PM   #13
ME
sparks1032's Avatar
I fixed the striker by drilling a hole for a cotter pin so the shaft would not spin when the knob is turned. Then I tried the washers under the cooktop and it worked for one cooking session and pushed through AGAIN! Not sure what the next step is, I wonder if the washers cause it to sit higher and the cover pushes down on it when its down and we are driving
Old 10-29-2012, 09:45 AM   #14
We went to Home Depot or Lowes and in the nuts and bolts isle found a piece that works perfectly with the stove top. They are some kind of a nut but we can't remember what kind. They look just like the factory ones only have a metal insert.
krischouinard is offline   Reply With Quote
