Old 03-08-2016, 02:57 PM   #1
Copilot desk mod
After searching for an aftermarket product for a while, I was unable to find anything that would work.
Here is a small co-pilot desk I built for my wife. The cost was about $30.00
Name:	ImageUploadedByForest River Forums1457470510.948535.jpg
ID:	101404Click image for larger version
Name:	ImageUploadedByForest River Forums1457470524.182956.jpg
Preadus is offline   Reply With Quote
Old 03-08-2016, 03:35 PM   #2
Senior Member - Retired
I really like that MOD. How is the unit attached to your dashboard?
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 03-08-2016, 03:40 PM   #3
Which model?
What model Georgetown is that?
Melvinson404 is offline   Reply With Quote
Old 03-08-2016, 03:43 PM   #4
I set the desk in place on top where I wanted it and marked it with blue tape. I them measured in 3/8 inch and drilled holes down. Then put the desk back in place and I used a couple extensions and a drill bit to drill up through the holes into the desk to prevent the wood from splitting. Then used wood screws to screw up from under the dash. It is very sturdy.
The one thing I need to figure out is how to keep the slide out if I slam on the brakes.
Old 03-08-2016, 03:44 PM   #5
It's a 2014 351
Old 03-08-2016, 03:58 PM   #6
What wood did you use and what wood finish?
2013 Smart Car TOAD
Old 03-08-2016, 04:04 PM   #7
I used a
1 - 2'x4' piece of oak 3/4" ply
1 - 1x4x6' solid oak plank
1- 14" full drawer slide
I don't have the stain color.
I probably would have used maple or cherry if it was available, because I think the grain would match better.
Old 03-08-2016, 04:18 PM   #8
I sent you a PM. Have a great day!
2013 Smart Car TOAD
Old 03-12-2016, 09:34 AM   #9
What are the dimensions of the box and size of the shelf. Looks exactly what I am looking for. Even wife approved.
Truckdogg4 is offline   Reply With Quote
Old 03-12-2016, 09:46 AM   #10
If you "Slam on the Brake's/Run into something" your Wife might NOT want that "Slide out-Sticking Out" even with a seat belt on! Youroo!!
modifications
