Old 07-18-2013, 09:12 AM   #1
Angry Corroded brake lines
We have a 2011 30ft. Georgetown motorhome.Brakes went out without warning leaving campground on a hill.Towed to Ford dealer in Pa.Brake lines were corroded and had to be replaced.Cost was $450 and Ford would not cover the cost since it was 2 months beyond warranty.Is anyone else having this problem?We have never driven in snow or ice since we live in Texas.We haven't taken it near salt water either.
Inspector is offline   Reply With Quote
Old 07-18-2013, 04:53 PM   #2
Iggy's Avatar
Are you saying the exterior brake lines corroded from salt from the winter roads? How did they fail? Did they all start leaking?$450.. did they replace all the lines or just one?
If they had water in the the system they would corrode the interior as well as clog the lines from rust.
Is that what happened?
Can you be more specific. Thanks
This may be something we all forget about. Has anyone bleed their brakes regularly?
I guess old brake fluid and hurt the brakes like in a car.
Old 07-18-2013, 06:47 PM   #3
copsuno's Avatar
How many miles? l Have a 2011, 360 with 22,589 miles and currently in Nova Scotia and my brakes are performing well. As Iggy said, few more specifics please.
Logic will carry you from point A to point B. Imagination will carry you everywhere. "Albert Einstein". 2011 Georgetown 360, Bride of 45yrs, and 2014 Chev Equinox toad, what more could you ask for.
copsuno is offline   Reply With Quote
Old 07-18-2013, 10:29 PM   #4
Tim & Lisa Trempert
Ford maintenance manual says you must replace brake fluid every two years regardless of mileage. Otherwise condensation in the brake lines will rust through. I'm guessing that since they sit for long periods the fluid does not get hot enough to burn off the moisture on a regular basis like a car does.
Makes you wonder about the Lippert hydraulic system and if it accumulates moisture. Maybe that is one cause of all the failures folks have.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 07-20-2013, 06:48 AM   #5
Brake lines
Thanks,i didn't realize you had to replace the fluid every 2 years.Three lines were replaced.Before we leave Pa. for Texas we are going to have all replaced.
Old 07-20-2013, 07:05 AM   #6
KyDan's Avatar
IF I had a motor home that was 2 model years old and a brake line failed like
you said- I would report it to http://www.nhtsa.gov/
The national highway traffic safety admin.
Save your old parts and take photos and document as much as possible.
IF you had flushed and re-filled your brake fluid at the 2 year mark as suggested
I believe your lines would have still failed.
You did say they failed just out of the 2 year warranty period.
The damage was already there by the time you got to 2 years!!
I had a brake line burst in an OLD pickup truck a long long time ago.
I was hauling a ton of sand in a 1/2 ton truck and it failed at a stoplight.
Thank goodness there was no cross traffic.
A 2 year old motor home should NOT have rusted brake lines especially
since you don't live in snow country!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-20-2013, 08:50 AM   #7
Dodge Guy's Avatar
Yes they say to replace the fluid every 2 years. Except that I'm sure yours didn't rust from the inside out. I've never seen any brake lines rust from the inside. Always from the outside. I would make a call to the NHTSA. They like to know these kinds of things. And at only 2 months out of warranty the dealer could have at least done a warranty adjustment and split the bill. As the previous poster said the damage was done at the 2 year mark.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 07-20-2013, 08:59 AM   #8
you said- I would report it to Home | National Highway Traffic Safety Administration (NHTSA)
I have to agree, and wonder if the brake lines weren't faulty?
I just sold my 30 yearold pickup that was driven in the salt and mud all of its life and nothing like that ever happened.
2 years? C'mon man!
bakken is offline   Reply With Quote
Old 07-20-2013, 09:03 AM   #9
Iggy's Avatar
Anyway this message was very helpful as most are unaware that the book says replace fluid every 2 years. I didn't know it until I read this thread. Thanks
I will have 2 years next April and plan to have the fluid replaced. I may do it earlier because you have to account for whenit was made not your warranty time and how long it has been driven. So I guess I will have to do it in the fall or early winter.
Three quarts of Super DOT4 brake fluid and a few hours is worth the effort.
Old 07-20-2013, 02:42 PM   #10
HI Iggy
Good advise will do the same when Nov. comes around best $ spend .
Iggy did you go to the Forest River to have your ROOF checked ??? I FOUND CRACKES and delamination also keep us posted please
Thanks GEORGE
2012 280ds towing a Saturn LW 200
RED Baron is offline   Reply With Quote
