Old 01-30-2011, 01:51 PM   #1
dashonthedash's Avatar
Countertop extension
When I purchased my new Georgetown, it came with a countertop extension, which is stored under the dinette bench. It's not an absolute necessity, as I have plenty of counter space, but it is a nice little extra. The problem is, I can't figure out how to put it on. Dealer showed it to me, but didn't demonstrate it at the walk-through. There are two fold-down brackets at the end of the counter, and it looks like it should slide right onto those brackets, but it will only go so far because of a set of tabs that are on the extension brackets that keep it a couple of inches away from the counter. Anyone else have this extension, and is there some way to slide it all the way on past those blasted tabs?
Gary Shapiro, 2011 Georgetown 29' Class A
Dash, Molly & Lily - now at the Bridge and forever in my heart
Shadow - 4-year-old Greyhound
Hannah - 1 1/2-year-old GSD rescue
dashonthedash is offline   Reply With Quote
Old 01-30-2011, 02:50 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Our counter-top extension stays on the brackets and has a catch mounted lower on the cabinates to keep it from moving when not in the up position. I'm not sure if ours is removable from the brackets though. I'll check and get back to you with my findings.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-30-2011, 04:42 PM   #3
Mine is intended to be removable; it even has its own strap under the dinette bench for traveling.
