I did find that the 2nd fuse from the top was blown. I put a new 15 amp fuse in and it did not blow. However, the lights still don't come on.
I rotated the dial for the courtesy lights and I heard the relay click (middle one) in the fuse panel. So that portion works. The lights do not come on and using a test light there is no power going to the light fixture.
I pulled the dash open where the reading lamp switch is. I probed the connection for the reading lamp and there is no power there.
I will keep the post updated when I find my solution. Especially if I find a wiring diagram .
Update: The reading lamp rocker switch is not receiving 12 v (+). When I force feed it with 12 v(+) to the red wire from the cigarette lighter plug, the reading lamps work properly with the rocker switch. So no juice coming in on the red wire to the switch.
Targeting the fuse panel under the steps. 3 of the fuses do not have juice on either side of the fuse. mmmmhhh. Getting close. I am looking for a diagram of thatfuse panel where the 2 solenoids are.
Thank you.It looks like the battery control unit failed on one of the areas. So, they must have scrambled to re-wire everything behind the area where the camera is.
Thanks again
