Old 03-05-2016, 09:41 PM   #1
Cracked windshield.
Have a 2004 37 ft XL. Traveling back from Lake Havasu city
Noticed a cracked windshield upper right corner. Might have been a impact crack but didn't see anything hit it. When we were retracing hyd levelers heard pop. Not sure if that is what caused it. Anyone heard if the torque could cause a windshield to crack.?
joesoares99 is offline   Reply With Quote
Old 03-05-2016, 09:53 PM   #2
I should have googled this. Just found out levelers can cause windshield to crack.
Old 03-05-2016, 10:56 PM   #3
Iggy's Avatar
So after 11 years with the Georgetown and you think you cracked your windshield because of the levelers? Weird I have never seen anyone here have that issue.
Maybe it was a rock while driving?
Old 03-06-2016, 06:43 AM   #4
Levelers can cause them to push forward, can you tell if the windshield has moved at all, if you have body paint there would be a telltale edge where you can see the rubber pushed away from the paint
Carmen is offline   Reply With Quote
Old 03-06-2016, 09:48 AM   #5
jergeod's Avatar
I watched a guy leveling his DP which was tilted to one side just a little and as it leaned the other way that monster windshield cracked in two directions. He wasn't that far off level to start with.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 03-06-2016, 08:28 PM   #6
dhind's Avatar
So what is the trick to avoid breaking your windshield when levelling. I assume it not just good luck.
Dave
Dave & Michelle
2015 Georgetown 270SS
Calgary, Alberta
dhind is offline   Reply With Quote
Old 03-06-2016, 10:08 PM   #7
the trick is not to twist the motorhome, take the gear down til they touch the ground and then raise them in increments so that you don't cause abnormal flex
