Old 09-26-2014, 11:27 AM   #1
Retired Ford Tech
Creaky floor.
I have a 2008 350tsse, my floor is creaky when I walk on it in certain spots. I have no water leaks. It is most noticeable near the dinnette. We have been full timing since Feb 2013. The floor isn't sold, just creaks.
rvpezzano is offline   Reply With Quote
Old 09-28-2014, 01:50 PM   #2
Retired Ford Tech
Upon further investigation, I pin-pointed the spot that was most noisy. When I would step out of the dinette, the floor would creak. We have a runner that covers the original carpet to match our current decor. I screwed 3 1 inch screws in the area of the noise, and bingo it did the trick. My guess is, the material that is between the floor and the subfloor has shifted. My fix just stabilized it. The runner covers the screws.
Old 09-28-2014, 04:03 PM   #3
chrisbailey13's Avatar
sounds more like the original screws/glue that was used has worked its way loose. the Screws added was probably the best solution.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
