Old 04-26-2014, 10:28 AM   #1
Crock Pot on solid surface counters 2014 GT 328
Anybody used a crock pot on the solid surface counters? Any problems with heat damage? Making chili this morning. I put the crock pot on the underside of one of the range cover pieces just in case.
Scagsdale is offline   Reply With Quote
Old 04-26-2014, 10:52 AM   #2
BlakeB's Avatar
I worked for many years for a granite and solid surface fabricator and I can tell you that slow cookers should be no problem on solid surface. The thing you should watch are the toaster ovens and hot pans.
For piece of mind you could always invest in a bakery cooling rack to set it on.
TT = 2021 ROO 233S
(Previous)TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2016 F-150 5.0L SCREW
Pit Crew: DW (Robin)
Kids: 9yo DD (Riley), 5yo DD (Kennedy)
Security: Boxer (Harley), yorkie (Willow)
BlakeB is offline   Reply With Quote
Old 04-26-2014, 11:23 AM   #3
bob213's Avatar
We always use ours without a problem. If in doubt, a cutting board underneath should do it.
bob213 is offline   Reply With Quote
Old 04-26-2014, 12:17 PM   #4
lswartz's Avatar
That depends on how hot your chili is.
X2 on the hot pans. We have never had a problem with toaster ovens but there are some $20 ones that might be an issue.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 04-26-2014, 01:10 PM   #5
I know for a fact that corian warps if it gets hot enough. The thinner it is the more it is prone to warp.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 04-26-2014, 01:40 PM   #6
BlakeB's Avatar
I dont think you are seeing warping...probably melting. I know when we did residential countertops the Solid Surface (Corian) was built on a substrate which would not let it warp. May be different for RV's though. It will also scorch causing it to look hazy. Easily fixed though.
TT = 2021 ROO 233S
Old 04-26-2014, 04:10 PM   #7
We always use a cutting board under ours. Makes for a handy place to rest the spoon on too.
Old 04-26-2014, 04:17 PM   #8
BlakeB's Avatar
We used to make cutting boards out of the sink cutouts and give them to people when our installers showed up. We had thousands of them laying around the shop. I bet if you found a local fabricator they'd give ya one cheap.
My countertops in my TT are LG Hausys HiMacs material. Not sure if FR used them for all of their tops though. It's the same material as Corian. If you have an area you can see under your tops it will have the name printed on them. (saw the underside of mine in the outdoor kitchen)
TT = 2021 ROO 233S
Old 04-26-2014, 04:53 PM   #9
Krazymace's Avatar
We've used our crockpot several times with no problems.
Krazymace is offline   Reply With Quote
Old 04-26-2014, 06:44 PM   #10
Happily Retired Member
Be leery of condensation. We always open a roof vent.
Mickeystamper is offline   Reply With Quote
Old 04-27-2014, 07:49 PM   #11
Thanks for the replies. Didn't see any discoloration on the underside of the range cover. Looks ok.
Old 05-02-2014, 11:47 PM   #12
gspage53
gspage53's Avatar
Send a message via Yahoo to gspage53
We had HiMacs installed in our home kitchen counters by the company that makes it. The rep said 250 degrees is the highest temp they can handle. Anything over that and it will melt.
gspage53 is offline   Reply With Quote
Old 05-16-2014, 06:23 PM   #13
I always put a dishcloth on the counter, then a cookie sheet and place the crock pot on the cookie sheet. That way you are covered for any kind of mess that might happen while cooking with a crock pot.
dirievi is offline   Reply With Quote
